Old 04-25-2015, 01:01 PM   #1
TazmanB
TazmanB's Avatar
2015 6.2 swap help
So I know that there endless knowledge to be found here and I need some help with a question. I have read and followed several LSx swaps here but have not found one using a 6.2 from a new 2015 Silverado. I don't know what, if anything, has changed on the 2015 6.2 power plant. My question is does anyone know if I will be able to transplant it in to my 69 C-10 without a lot of work? Or will I be able to get a stand alone harness that will make it work? The reason I am asking is that I had a complete 2015 6.2 motor/trans fall in my lap and would love to be able to put it in my 69. Any info would be great!!
If you ask the question. Make sure you are ready for the answer.
69 C-10 Longbed (In Progress) Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=568171
TazmanB is offline   Reply With Quote
Old 04-25-2015, 02:13 PM   #2
Clyde65
Clyde65's Avatar
Re: 2015 6.2 swap help
Taz, Holler at Clienbarger, he is in Fort Worth and does these swaps for a living among other things.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-25-2015, 09:41 PM   #3
clinebarger
I have not messed with the EcoTec-3 engines yet. I recommend staying away from them 'til GM gets all the quirks ironed out.
I am still on the fence as far as Direct Injection on gas engines, It causes Intake valve deposits to form (quite rapidly), And are known to dilute the oil with fuel.
All EcoTec-3 engines have AFM. GM didn't have this stuff worked out in the Gen IV engines.
The first couple years of any new powertrain from any manufacturer usually has issues. The LB7 Duramax, '97/'98 LS1, '03 Dodge Hemi, 6.0L Powerstroke, 3 valve 5.4L, & Northstar are good examples.
Also keep in mind, That with swaps....There will be no manufacturer warranty. These new DI engines may turn out to be a good powertrain, But NOBODY knows yet!
clinebarger is offline   Reply With Quote
Old 04-26-2015, 01:39 AM   #4
mattcrp1
mattcrp1's Avatar
I agree with you on first year power plants, I saw a lot of 03-04 6.0l Fords bought back. So far the DI gas engines are really good. They run crazy static compression ratio's, pre-ignition is a non-issue.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 04-25-2015, 04:43 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
New gen LT1 swaps are a bit hard at the moment. The computer is a deal more complicated, and thus the wiring is more troublesome. I'm not sure how far they've cracked the O/S for those yet, whether or not they've got trans controllers working etc.
IMO the biggest thing you face is dealing with the DI system, which operates at a much higher pressure. Its a great system, but its also designed around running near-full capacity from the factory.
The "big guys" like Lingenfelter, MAST etc are just starting to really get into the systems, so it might be a little while before a plug-n-play solution comes up like we now have for the LS swaps.
That being said....might be worth holding onto for the summer and seeing what new stuff develops. (keep in mind that the parts costs for these motors are VERY high atm)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-25-2015, 08:10 PM   #6
JJH Jimmy
JJH Jimmy's Avatar
Speartech has them figured out but they are pricey. If you are willing to wait I am sure the price will come down when others get them figured out.
http://www.speartech.com/category_s/1836.htm
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 04-25-2015, 08:40 PM   #7
TazmanB
TazmanB's Avatar
Thanks. I will look him up
I agree. That's why I snatched it up and couldn't pass it up for the price. Even if I have to hold on to it for a bit.
I was just looking at that. It finally hit after days of google searches. Thanks for the advise every.
Old 04-26-2015, 12:58 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Heheh the Lb7 was junk allllll the way through. Engine design was ok, induction and fuel system was trash.
As for the carbon deposits thing, I've heard that a ton of super late model Audi/VW products. Require 91+ octane, TSB for de-carboning (is that a word) the intake from deposits, and still costs way too much.
