Old 04-25-2015, 11:50 PM   #1
canadian_diesel1964
Generator light stays on when truck off...after new alternator.
I can't figure it out...light stays on ...truck is off...after the new alt install....
canadian_diesel1964 is offline   Reply With Quote
Old 04-26-2015, 01:43 PM   #2
ACK
ACK's Avatar
Re: Generator light stays on when truck off...after new alternator.
Just want to confirm, if you take the key out of the ignition, the alt light stays on? Did you upgrade from ext to int regulated alternator?
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 04-26-2015, 03:07 PM   #3
zplightning
My truck does this if I turn the key to the far left, left of the off position - not sure if that is some sort of accessory setting but might be something to check. If I remember correctly "off" is the notch to the right of that.
zplightning is offline   Reply With Quote
Old 04-26-2015, 04:43 PM   #4
canadian_diesel1964
Hey guys yes I have the key out I upgraded to a new alternator the internal regulated alternator change had already been done
Old 04-26-2015, 08:43 PM   #5
canadian_diesel1964
I'm getting 12.32 volts on the number one terminal of the alternator with the power off,..I'm thinking I have a short inside the alt?
Old 04-26-2015, 10:40 PM   #6
Wrenchbender Ret
Sounds like the alt. has a shorted diode.
Wrenchbender Ret is offline   Reply With Quote
Old 04-26-2015, 10:50 PM   #7
canadian_diesel1964
Thank you...I'm thinking so too
Old 04-27-2015, 06:13 AM   #8
brokenspoke
brokenspoke's Avatar
Check out "madelectrical" lots of inf0
brokenspoke is offline   Reply With Quote
Old 04-27-2015, 03:50 PM   #9
canadian_diesel1964
Thank you...I did...very good info...I called the place that sold me the alternator and they have ordered me one that will work...
