Old 04-26-2015, 02:20 PM   #1
jakespade
jakespade's Avatar
How low can you go?
Interested in seeing how far a 79 short box can go without having to cut into the bed. Riding on stock height wheels.
Any pics?
jakespade is offline   Reply With Quote
Old 04-26-2015, 02:54 PM   #2
J1MMY
Re: How low can you go?
I've just measured up for flipping the axle on mine (@5-6") and the chassis rails will need notching although the diff shouldn't hit the bed. Shock stiffness will also be a factor. I must confess to having no idea of stock tyre size as mine has been fitted with 31 x 10.50 -15's by a previous owner.
J1MMY is offline   Reply With Quote
Old 04-26-2015, 03:05 PM   #3
jakespade
jakespade's Avatar
Thanks J1mmy. I am looking at a 79 and it's already lowered on rallies, looks to be stock size rubber. I am thinking it would pretty good bagged, but if I get a truck, I need to make sure the bed floor isn't adjusted.
Old 04-26-2015, 03:09 PM   #4
J1MMY
I love my 79 - it's rough n ready but a rarer sight over here than the earlier and later model trucks. How has it been lowered up to this point? Leaf removal? Shackles?
Edit - I'm guessing that stock tyre size is 235 75 15 as per most 1/2 tons of the era?
Old 04-27-2015, 12:48 AM   #5
Titomars
Titomars's Avatar
Actually the standard tire size for 1/2 tons was H78-15 which to the younger crowd is a 225R75-15. The 235R75-15 would be an L78-15 which was optional
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 04-26-2015, 03:11 PM   #6
jakespade
jakespade's Avatar
It was done with a flip kit in the rear and spindles up front 3/4
Old 04-26-2015, 03:13 PM   #7
J1MMY
Flip kit only did 4"? Hmmmm...got a pic or link?
Old 04-26-2015, 03:18 PM   #8
jakespade
jakespade's Avatar
Not with me. On the phone shopping with the missus...
Old 04-26-2015, 03:53 PM   #9
J1MMY
Yikes!
Old 04-27-2015, 12:25 AM   #10
jakespade
jakespade's Avatar
It wasn't so bad.
Any suggestions on a budget air bag set up for a 79?
Old 04-27-2015, 05:06 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Look at member Jwalls truck. He has before and after of static and bagged with just a C notch out back.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-27-2015, 05:19 PM   #12
JWall
Frequent Flyer
JWall's Avatar
This is with a 27.5" rear tire size
This is the absolute lowest you can go without the rearend hitting the bed floor. Has a bolt in c-notch with bagged suspension.
Before bags with static drop & same c-notch.
- Justin
1 Owner 1976 SWB
Old 04-27-2015, 05:26 PM   #13
jakespade
jakespade's Avatar
Thank you!!! I think if I get it I'll leave it where it's at. If I go any lower I'll bag it if I can piece together a set up.
That truck looks beautiful by the way
