But Found Her 25yrs Later!
![]() Join Date: Oct 2010
1 Man - Installing and/or Removing Hood.
Any ideas on One Man Installing and/or Removing Hood?
I don't have an engine puller.
Re: 1 Man - Installing and/or Removing Hood.
Ive done it with 2 long prop rods on a couple of cars before, should be the same process
Wait. For help
1965 C10 Project |
![]() Join Date: Mar 2013
I did it....used the forks of my tractor and that propped the hood, let is slide off the brackets and then lowered it...then got underneath and man handled it off. lol I've also done it when I propped the hood with my head and let it fall on me.....the 1st way is a tad less painful though.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Maybe use a ratchet strap on each corner and raise it up then back from under it??
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721 Instagram: jaked937 |
yeah, this has always been my method too. Cabs & beds no problem....but the hoods especially when painted I wait and get help on.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
this is how i did mine. had a few tie-downs---
1961 chevy K10 my build is------------61K10 build |
. I think I'm going to try this. The pictures helped. Thank you. . And thanks to the other's too.
Senior Enthusiast
I did mine in a similar fashion with a cherry picker. If I didn't have that, I'd bolt substantial brackets to the ceiling joists and lift the hood with ratchet straps., and as noted above back the truck out from under. Just be careful when it comes time to release the tension. I use ratchet straps for all kinds of things, including hood spring installation.
We don't have any help readily available, so waiting isn't much of an option. I figure out an engineering solution rather than stop progress.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
suppose I could come by and help you...im going to be removing my hood soon so you can come help me...lol
![]() Join Date: Aug 2008
In a pinch I put some rags on the cowl, unbolted one side at a time. Then just reached under the hood at the center and lifted it overhead. It was pretty darn heavy though. Cherry picker and a few straps makes it easy.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Who Me?
61K10 has the right idea.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
I have done it, but I'm 6'3" and 245 which helps but I usually just walk inside and drag the wife out to help.
#15 |
1961 crewcab
this doesn't help much... I am just jealous of the clamp they got to use at the factory.... it hooks under the front lip, and then has a rest in the center....
I have found that I can get a hood off by myself with out scratching the paint, but there is pretty much no way to put it on with out tearing stuff up! *** also check out that cool tire stand.. I need one of those for my 4X4!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#16 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Im about 15 minutes and a six pack away.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#17 |
#18 |
Thanks guys.
I was able to get help today. I think I'm going to go buy an engine hoist for next time. I'll need it for future projects anyway.
#19 |
The only way I have ever been able to do it alone is with an engine hoist. It's the single best tool i own, comes in handy for so many things.
1963 Chevrolet C10 Stepside 1972 Pontiac GTO 1998 Dodge Viper GTS 1999 Jeep Cherokee XJ 2018 Chevy Camaro ZL1-1LE It's never too early to beef up my obituary |
#20 | |
![]() Quote:
![]() s |
#21 | |
![]() Quote:
Radiator stayed bolted up too. So, I learned a lot on that day! Sam |
