Grille
Not sure what this bracket is made of can I use regular wire in my mig welder and weld a new nut on here? Any help would be appreciated... tonight I go and pull out my hair and see if I can't get the bottom two bolts in the front bumper.
64 Step Side - The Mistress |
Re: Grille
Helps if I actually attach the picture.
1961 crewcab
Re: Grille
pretty sure the brackets are steel even on the aluminum grilles.
you could check it with a magnet.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Grille
Yes the brackets on the back of the 63 grille are steel even on the Silver Anodized Aluminum grilles.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Re: Grille
thanks guys... welding the new nut right in there this morning - just need to extract one other one that broke off and should be able to put this thing back in place... progress is slow. Thanks again.
-Wayne
Re: Grille
Even slow progress is progress wayno.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: Grille
Thanks Man... I have to remind myself of that. Picking up some new halogen's and and then I can focus on wiring into the new relays.
Re: Grille
thoughts on these headlight covers..... can't decide whether I like them or not...
Re: Grille
Not im my opinion. Look more like they'd fit on something 40-50's
Re: Grille
