Old 04-28-2015, 03:25 PM   #1
OldChevy61
OldChevy61's Avatar
62 c/10 front suspension
Who can tell me a little about the front torsion bar suspension. I've messed with a lot of coil springs,but never torsion bars. I'm looking at dismantling this thing to bare frame, or not lol. Just don't want anything flying out in my face.
OldChevy61 is offline   Reply With Quote
Old 04-28-2015, 07:04 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 62 c/10 front suspension
Get your truck up off the ground. Loosen the bolts the adjust the tortion bars. I think they take a 15/16 socket. They should loosen up and take tension off to remove them.. The rear part of the bar just sits in a pocket and will come down when you take off the lower control arm off.
When I replaced my lower ball joints they came apart easy.
If you plan to keep the bars, it will be kinda tricky to get them readjusted to keep the truck level. I kinda did that by eye.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-28-2015, 09:04 PM   #3
LVPhotos
LVPhotos's Avatar
Lots of penetrant I used WD40 new stuff, PB Blaster or the like. Tightening gets lift, loosening gets you lower. Support pork chops with jack and loosen bolt lower jack. It s like letting a spring down slowly. Use a big bar or punch to push bars out of arms. Rest is just bolts.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 04-28-2015, 09:18 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
X2...lots a lube before you dismantle anything.
