![]() Join Date: Jul 2000
73-87 steering column differences
What year auto trans steering columns will fit a 1982 truck?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Re: 73-87 steering column differences
should be anything from 81 to 87. the earlier years would need to be modified slightly to work properly. ive had an 82 column in my 86 and worked fine
After doing some research, looks like 79-83 pickup columns are the same for auto trans WITH and W/O tilt.
Starting in 84, I think the wipers and high beams were controlled by a stalk on the column.
Isn't the wipers on an 82 dash mounted and 86 it's column mounted?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
Moderator
![]() Join Date: Oct 2008
84 and later are column mounted.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
I replaced my busted column in my '77 GMC K25 with one from a '90 suburban. Im actually swapping most of the interior over as well. I used the '77 upper column dish on to the newer column so I could keep the same ignition key and simple turn signals and still have the wipers on the dash. I used the 90 hazards, ignition and neutral switch. Everything bolted up and worked fine. I used a Borgeson steering shaft from and older project. Pretty easy except for the dang rust on the donor vehicle
Moderator
The electrical connections are the same 78-83.
85-91 will fit with or without moving the dimmer and wiper control to the turn signal stalk.
Moderator
You can avoid the lower shaft mismatch by using the shaft from your donor or building a U-Joint shaft.
I need a tilt steering column WITH cruise for my 81... seems to be a unicorn to find.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
#11 | |
This guy is worth a try: http://www.gmtiltsteeringcolumn.com/ I bought a very nice 82 tilt/auto column from him.
#12 | |
Moderator
The difference between with Cruise and without is the turnsignal stalk. The columns are the same. There are at least two cruise stalks with the early transducer controls, floor dimmer, and dash wiper switch.
84-91 Cruise control accounts for at least two more different stalks.
While I'm on the subject... There is absolutely no utility in getting the 2 speed switch in your 1984 on steering column. The cab harness will plug right into the delay box and the non delay 2 speed column wiper switch is around twice the price of the delay switch. To add insult to injury the non delay 2 speed column switches are hard to find too.
