04-29-2015, 07:35 PM | #1 |
'Handy Man Jack' The service Truck
I figured I would start a thread on my current project. It's a 68 c10 that started life as a gmc. I swapped it to right hand drive, lowered it with a porter built dropmember. The frame has been shortened and the rear suspension built by me. I decided to build a bagged truck that was useful. Well as useful as slammed truck can be. I'm planning to run a ls in this one. Still undecided on a turbo though. Anyone have any advice on how to keep the pictures in the thread? My builds always lose the pictures. Thanks, hope you enjoy!
My Patinia'd 69 69-http://67-72chevytrucks.com/vboard/showthread.php?t=517537 My RHD 68 http://67-72chevytrucks.com/vboard/s...d.php?t=594928 |
04-29-2015, 07:38 PM | #2 |
Re: 'Handy Man Jack' The service Truck
Here's some progress shots
04-29-2015, 07:40 PM | #3 |
And more
04-29-2015, 07:43 PM | #4 |
Here's the air management I stuffed in there.
04-29-2015, 07:45 PM | #5 |
Here's how it sat for quite some time.
04-29-2015, 07:48 PM | #6 |
Here's where it began to take shape.
06-07-2015, 12:47 AM | #7 |
I'll follow along, I dig it
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
06-13-2015, 07:20 PM | #8 |
I started shaving the cowl today and turned it into a genuine nightmare. I got out of hand with the grinder and shrunk it big time. It was almost perfect when I was done welding though. Here's some pictures after a hour of beating it back into shape. I also got rid of the factory rear crossmembers and made some tubular ones.
06-14-2015, 08:26 PM | #9 |
Well I got the cowl fitting a bit better but still have a ways to go. I successfully ruined my windshield too but oh well.
06-14-2015, 09:29 PM | #10 |
I see surface rust forming, but when I had bare panels I was amazed on how long they'd go without forming any (inside garage). Good steel.
project: "my happy mess" |
06-14-2015, 09:49 PM | #11 |
Yeah it's getting some rust from the shrinking process I have to spray water on the heated steel to form it and it gets everywhere. I figured I'd leave it be until all the metal work is done then I'll fix all of that. It is some good steel but it's no where near as good as my 54 that stuff is incredible!
06-14-2015, 10:25 PM | #12 |
I bet it is. The further back in history the better. Looking real nice. I'm sure you know you just don't want any pitting to start with that rust but light surface just wipes off easy.
06-14-2015, 10:29 PM | #13 |
By the time I'm done with 80 grit and epoxy primer no one would ever know it was in such a sorry state but that's the price of making metal that straight
06-14-2015, 10:42 PM | #14 |
True, you're doing it the right way. What happened to the windshield? Hot metal splatter from the welding or grinding melted to it? Happened to mine.
06-14-2015, 11:30 PM | #15 |
Yeah some dummy got weld sparks on it. I used cardboard, but it didn't stop much I guess. it's pretty bad but I work at a glass shop so I'm not the least bit worried about putting another one in
06-15-2015, 01:06 AM | #16 |
looks good maybe someday when i am not so busy i will get a chance to come by and see it
https://www.facebook.com/CrazyKidsCrazyPaint bagged chopped 70 build http://67-72chevytrucks.com/vboard/s...d.php?t=605638 ol fishing truck build http://67-72chevytrucks.com/vboard/s...d.php?t=654852 |
06-19-2015, 11:44 PM | #17 |
Starting to play with the idea of a flip up cowl vent since I don't really want to give up that much air. Also got the cowl fitting the truck a lot better than before I don't think it even fit that good when it was new!
06-28-2015, 05:58 PM | #18 |
Man this thing is awesome. I likes it.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
07-07-2015, 03:54 PM | #19 |
very cool
07-09-2015, 07:10 PM | #20 |
Thanks for the compliments guys. I don't have much of an update as I haven't hardly seen the truck in the last couple weeks but I did get my hood hinges and I'm picking up a fresh small block tomorrow for the old girl.
07-10-2015, 09:26 PM | #21 |
I got my motor tossed in today. It's a 350 with a cam and supposedly 500 miles. It came at a price I couldn't refuse so I pulled it after work and put it in mine. I need to build some valve cover adapters so I can run staggered covers on square heads. I've got a set of ram horns lined up for it as well.
07-10-2015, 10:12 PM | #22 |
Looking good
07-11-2015, 06:26 AM | #23 |
very good looking
07-12-2015, 12:06 AM | #24 |
I got started on the porterbuilt hood hinges tonight. I'm pretty disappointed in them to be honest. The hood plates were messed up big time. The nuts weren't even close to being centered on the holes when they were welded so I had to drill the holes out about 3 sizes to get the bolts to start then they all siezed in the nuts even with antiseize so tomorrow morning I'll cut all the stainless bull **** off and install some hardware that can actually be used.
07-12-2015, 01:39 AM | #25 |
That sucks man about the added work with the hinges, as if there wasn't enough already. But they do look pretty sweet when they're done.
