Old 04-30-2015, 02:23 PM   #1
Motor City GMC
Need help please
So I got a steal of a deal on a 1979 K30 with 49k original miles on a 400 small block,out of california so it has all of the smog and emissions on it, including the smog pump (I believe its the pump directly under the alternator) that is still hooked up.
What I need help with is I want to remove all of the emissions and not needed vacume lines, but i dont have a clue as to what i can remove or where to start. I dont want to just start disconnecting things not knowing what im doing.
So can anyone give me some very detailed and step by step instructions on what exactly i can remove.
I plan on puting headers, intake and carb on it at some point this summer.
PLEASE HELP AND THANKS!!
1979 Scottsdale Trailering Special K30
Motor City GMC
Motor City GMC is offline   Reply With Quote
Old 04-30-2015, 09:50 PM   #2
midnight rambler
midnight rambler's Avatar
Re: Need help please
Check out gregskis post i believe he did that on a c10
midnight rambler is offline   Reply With Quote
Old 05-01-2015, 09:51 AM   #3
cadillac_al
The only things that need vacuum is the distributor and the trans. Everything else is unnecessary.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-01-2015, 12:48 PM   #4
Motor City GMC
So i can just yank all of it out and will not have any problems?
I dont need to cap anything or do nothing besides eliminate it?
Motor City GMC
Old 05-01-2015, 01:05 PM   #5
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Eliminate everything you can and just cap off all the vacuum ports on the intake and carb. The EGR valve itself can just be unplugged. It won't operate without vacuum. The tube going from the AIR pump to the cat will have to be plugged off somehow.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 05-01-2015, 01:09 PM   #6
tucsonjwt
Don't get rid of the smog stuff when you remove it. Some states require that factory emissions equipment remain in place in order to pass emissions. Someone may want that stuff.
tucsonjwt is offline   Reply With Quote
Old 05-01-2015, 01:10 PM   #7
lindstromjd
Agreed.
-357 / 700r4
-350 / TH350
Old 05-01-2015, 01:50 PM   #8
Motor City GMC
So the only thing i need to leave is the vacume to the distributor and the trans?
Nothing to the carb?
What about the hose or tube (i dont know what to call it) that goes between the old air box and the manifold? Can i just disconnect and leave open or does that need to be plugged off?
Motor City GMC
Old 05-01-2015, 01:52 PM   #9
Motor City GMC
The smog stuff will probably just go on ebay/craigslist to someone who wants/needs it
Motor City GMC
Old 05-01-2015, 06:57 PM   #10
Motor City GMC
On another note, can anyone tell me where the vacume line that runs the heat and a/c vent inside the cab comes from or originates?
Motor City GMC
Old 05-01-2015, 11:11 PM   #11
cadillac_al
Either at the back of the manifold near the distributor or to the back of the carb. Anywhere it can get full manifold vacuum.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 05-02-2015, 05:24 PM   #12
Motor City GMC
Are there any differences in the emissions systems for a 350 vs a 400...i ask because i see diagrams for ppl posting about there 350's b7t nothing about the 400's
Also mine looks to have 2 canisters, one one the drivers wheel well and the other on the drivers side next to the radiator, eliminate it all???
Motor City GMC
