What's your philosophy on parts and why?
Do you go nuts for NOS and OEM or are aftermarket parts fine with you? What's your reasoning?
![]() Join Date: Jan 2002
Re: What's your philosophy on parts and why?
I use OEM where I can. Especially body parts. But have no problem using aftermarket parts either. Things like alternators, or starters, anything like that I have no problem going to O'Reillys and buying. I drive all of my trucks and use them as trucks except for my Cheyenne super so I can't see spending nos money on parts that could be damaged.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
1. Used OEM, preferably from the same MY and assembly plant as it will be closest and representative of parts a given vehicle was produced with.
2. Service Parts, GM qualified REPLACEMENT parts. While not generally production parts they at least function correctly and for the most part fit without modification (depending on supercession and backfitted applications). Always try to find the earliest P/N possible not the easiest to find. A part made 20 years later by a different contractor to a different drawing isn't necessarily going to mimic an original production part. 3. Reproduction, By and large reverse engineered. Some claim to be made to "original drawings" but which, production or universal fit service part drawings. They can range from very good to something worse than a 10 year old kid can make. All too often people depend on reproduction parts that are primary visual points or expensive to install structral components by price point. If the quality isn't in the box it won't get better installed.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
![]() Join Date: Sep 2007
my philosophy.......parts is parts
![]() i like to use oem when i can on body stuff as well but enginecomponents im fine with using auto parts store stuff. trim items? well if was building a show truck i guess id use aftermatket on the little stuff and refurbish oem bumpers and such
1967custom |
Impossible to answer without knowing what you're doing. A NOS battery will run you $1500. A parts store batter could be $65. What scenario are we talking about here?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#6 | ||
"I ain't nobody, dork."
Parts is parts. I also realize you get what you pay for. Plus... some USA made parts fit just as crappy as offshore stuff. So it's always a crapshoot.
But I can usually make almost any part work as advertised whether it fits crappy or not. Depends on how big of a hammer I use. ![]() If a cat goes into it with the mindset that every single part (no matter where it's made) is just going to fall right in to place and line up each an every time... then you live a fairy tale life. If playing with old rigs was easy... everybody would be doing it. ![]() Gary
Good parts aint cheap. Cheap parts aint good
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
motor exploder
I use the best parts I can afford. With that being said, I'm also a bit of a parts snob
![]() Good thing is, we have a forum like this to learn and ask questions about things, so it helps to minimize the mistakes. Sheetmetal always seems to be an issure. I tried (and did) use a LOT of my OEM sheetmetal after hearing stories of poor fitting aftermarket stuff. I ended up having to butcher up the aftermarket rockers I bought so they would fit - I probably should have ponied up and found some NOS ones - but I did get a good lesson in metal working and patience from the install. For suspension & brakes I buy the nicest stuff I can get - MOOG, Raybestos, Wagner, etc. Same with driveline parts & electrical. You can't cheap out on that stuff. I used to work as a project manager for an aftermarket parts manufacturer (Cloyes Gear & Products) they make aftermarket replacement, high performance and are OEM for a lot of stuff as well. Cloyes is well known in the engine parts industry for making high quality parts - I had a lot of pride working for such a company. But it's also interesting (and sad) how some parts are just thrown out onto the market by companies that know they are making absolute junk and have no problem with that fact. It's up to us as enthusiasts to help each other out and avoid those companies. That being said, some people just buy the cheapest thing they can get their hands on and then complain about it not fitting right, failing or not working at all. There will always be a spot in the market for that.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Moderator
![]() Join Date: May 2007
Depends on the part, the price, and it's function.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Personally I don't care what name is on the box as long as the quality is there. For instance I would rather have a Holley or Edelbrock (Carter AFB) carb than a NOS Quadrajunk oops I mean Quadrajet.
![]() Join Date: May 2014
But those are all names.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
I don't really care as long as the part looks and fits like it should.
I feel that the more original my truck is, the better I'll feel and the more it will be worth. Also, I would think NOS or OEM parts will fit pretty well. So, NOS where possible (affordable), OEM when good and affordable, aftermarket where I have to. "Perishable" items such as electrical and mechanical, I'll most likely have to get from an auto parts store. I am happy that I have most sheet metal parts that I need NOS, with just cab corners and some cab floor left to get (should be able to get those from a cut up truck).
#15 |
Vintage 4x4s
Oem had specifications that assured the parts would generally fit together pretty well. Aftermarket is a crapshoot, some don't have the right dimensions or any prints with dimensions to build to
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#16 |
Cluster King
![]() Join Date: Nov 2012
To me it is also a challenge to see how many OE parts I can get in the condition I want for my truck. The K20 is not going to be a show stopper, so I am not concerned if the OE sport bumper I find has a few dings in it hear and there.
There are some things you just cant get OE or NOS that have a good quality or appearance anymore. Gauge cluster bezels are a perfect example. I have never seen a NOS chrome and black bezel and if I did it would cost $500.00. The OE's are hard to find with good chrome. They are out there but an OE with perfect chrome is not very common at all which forces us to go with aftermarket. I would rather have an OE steering wheel with a few cracks than an aftermarket. I would rather have an OE tail light lens with a chip in it than an aftermarket and so on and so on. I guess it is to each his own on this topic. Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
