72 door panels
Ok, so I finally got a nice of OEM plain Jane black door panels but I now need arm rests. Any opinions on who sells reproductions of high quality?? Also wondering if I can install wood grain inserts on these and details of what it requires. Maybe some pictures. I am looking at the aluminum reproductions at the truck shop and wondering if they are any good and also is there a trim ring required. Any help greatly appreciated. Thanks
Re: 72 door panels
Vetted please
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: 72 door panels
You will need to drill the holes for the retaining ring to go into. It keeps the wood grain attached to the door (not reproduced). The new aluminum panels are good quality, though the wood grain pattern is not 100% authentic. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Re: 72 door panels
Thanks Trevor, are you aware of a source for the retaining rings.
SWB 4x4 Collector
Re: 72 door panels
You will have to buy a used set of rings from a board member, eBay, or junkyard. Might have to buy a junk set of door panels for the trim. Trevor
Re: 72 door panels
Used Parts on parts board maybe WTB 72 door panel. trim.....I painted mine a lot of work and not as nice as original... Here SWB did a nice job DIY vinyl wood grain. http://67-72chevytrucks.com/vboard/s...d.php?t=660030
Re: 72 door panels
Got it. Thanks again
![]() Join Date: Aug 2008
Re: 72 door panels
I have a question relAted to the cheyenne door panels. I have a pair of custom deluxe door panels with the scroll pattern and stainless trim. I always thought that the stainless trim could be removed and the cheyenne wood trim installed in place. Is this true? I have a cheyenne but it had some "customized" panels installed by a previous owner. I ran across the dArk green panels I have in another cheyenne (without the woodgrain for some reason) and since they were pretty nice, repainted them black and installed them in my truck.
All about them K’s
![]() Join Date: Jun 2014
Re: 72 door panels
yup just remove the stainless trim, add the wood grain inserts, then reinstall the the trim. Be carefull not to break any of the tangs that hold the trim on.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
