05-02-2015, 06:03 PM | #1 |
What kind of mpg could i get out of these setups?
366T BBC 4.10 gearing 700r4 tranny
336T BBC 4.10 gearing th400 tranny 366T 373 gearing th400 tranny 336T 373 gears 700r4 tranny 1986 k5 blazer 33 inch tires 4 inch lift 4 wheel drive Last edited by DustyNova; 05-02-2015 at 06:09 PM. |
05-02-2015, 06:12 PM | #2 |
Re: What kind of mpg could i get out of these setups?
I will guess - 8 mpg with any of those set ups. (If you don't get on it.)
05-02-2015, 07:52 PM | #3 | |
Only way to get 450 hp out of that chunk is with a 300 shot of goofy gas!! As for the 402 crank. The 366 has the same one. Same stroke. |
05-02-2015, 06:20 PM | #4 |
can you tune a 366 up for good performance? like to 450 horse and 5 something torque?
05-02-2015, 06:22 PM | #5 |
also what does it make with a 402 crank in a 366 block also would it be better to have a manual or a automatic
05-02-2015, 07:51 PM | #6 |
I have a 454 with Q-Jet, TH400, and 3.73 posi. Around town 8 mpg is pretty normal and I drive with a semi heavy foot. On the highway I never checked what I get. I am guessing around 11 or 12 mpg @ 65MPH and spinning 3300 RPM.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
05-02-2015, 08:37 PM | #7 | |
Perhaps your speedo is off or you have 4.11 gears.
1982 K10 SWB 1987 V20 - Sold - Doh! |
05-02-2015, 08:43 PM | #8 |
speedo does not work yet. I checked with a GPS. I have 27.5 inch tires in the rear
05-02-2015, 08:49 PM | #9 |
is it worth building? am i better off building a 427?
05-02-2015, 09:17 PM | #10 |
05-02-2015, 09:21 PM | #11 |
im sure i can get a 454 block at the wrecking yard i mean couldnt i just order a 427 crank and pistons and itd be the same thing?
05-02-2015, 09:32 PM | #12 |
You can make a short deck 427 from a 454 block. Check the specs between each motor.
http://en.wikipedia.org/wiki/Chevrolet_Big-Block_engine But don't just go order a crank and pistons without getting and checking out a block first. If you've got the coin just stroke a 454 and make a 496. There's no substitute for cubic inches!! |
05-02-2015, 09:37 PM | #13 | |
05-02-2015, 09:46 PM | #14 |
05-02-2015, 10:00 PM | #15 |
There's a 600ci small block all aluminum.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
05-02-2015, 10:52 PM | #16 |
From what I'm finding it has 4.6" bore spacing and 10" deck height, so not much of a small block.
1973 C20, 350/350 |
05-02-2015, 09:40 PM | #17 |
In 1978 I ad a 2 ton Chevy set up for giant tire service had a 366 5 speed 2 speed rear.
Gassed up up going out town before I left drove 10 miles round trip ran about an hour boom and compressor ran off pto topped it off took 21 gallons. I figured it got around 2to 3 mpg 2 45gal saddle tanks. I would say bad very bad.
05-02-2015, 10:02 PM | #18 |
1000ci 0_0 LOL HOLY **** well i thinka ima stick with a 427
05-03-2015, 10:06 AM | #19 |
366/396/402/427 use the same cranks. 366 is designed for high load low to medium RPM, 4 ring pistons, peanut port small port heads. Usually has good steel crank and good rods. Take those and a 454 block and you have a stout bottom for a 427. None of these are MPG motors. 700R4 built to withstand a healthy big block costs more than the mileage over a TH350/400 gain repays for 50k miles.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
05-03-2015, 06:45 PM | #20 |
One of the advantages of the 700R4 is that it increases comfortable cruising speed. With my 350/350/4.10 on 30" tires, cruising speed isn't that high - I tend to stick to 55 or so. With OD I could probably cruise at 65 or 70. Fuel consumption may not be any better, but it's nice to get there faster. Of course, a taller rear end would also help, but that would sacrifice speed off the line.
1973 C20, 350/350 |
05-03-2015, 07:57 PM | #21 |
If you want mileage install a manual. I have gotten 8mpg average in a 454 longbed automatic 81 and 15mpg in a 454 longbed manual.
Same stock engine with only 9,000 miles separating the two. Both c10 trucks with stock engines. One had a TH-350 and the other had a sm465. Both had 4.11 gears. Both ran great. The difference was that I was able to coast a majority of the time with the manual running 800 rpm occasionally putting it back into gear and getting up to 70mph. while with the automatic I was running 3 times that at 70mph and could not do much about it. Once you have a manual decided you can look at the engine. The price to build a 496 is quite higher then just building a 454. A 468 can be built for way less time/money then a 496. Of course if your willing to keep a open mind there are other options. If you are after cheap torque and don't mind paying for premium fuel. The late 60's-early 70's Buick, Olds, Pontiac, and Cadillac Big Block engines put out around 500 ft/lbs and can be be had with a entire car for less then $1500 if your willing to look. The difference is that these engines have a high nickle content blocks making them lighter then 454 blocks. They can be built up to outrageous power numbers or will run great in stock form as long as you keep them under 4000 rpm. Adapter plates are out there to make them a easy bolt in deal. The only downside is that the B,O,P,C engine does cost more to upgrade/rebuild then your common Chevy engine.
1991 Metro commuter 1991 s10 future project truck 1987 V10 backup daily/junk truck 1985 K20 Winter beater 1991 R30(squarebody) c/c flatbed towrig 1994 s10 80"wb custom build |
05-03-2015, 08:55 PM | #22 |
I think the B,O,P,C engines are interesting, and the 500 ft-lb is nothing to sneeze at. But trying to couple these engines to an overdrive stick would be an adventure.
It's the Buick engine that's much lighter than a BBC. It was a new thin wall casting process.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
