05-04-2015, 06:33 PM | #1 |
Turn signal switch connectors
Does anyone know what the original GM part number for the connectors used in the turn signal switch and its mate on the dash wiring harness. I have a new turn signal switch, I just need the connector for the dash wiring.
05-04-2015, 06:39 PM | #2 |
Re: Turn signal switch connectors
Is your attachment from the turn signal switch flat? If so, and you are connecting to the half moon shaped dash harness, there isn't a GM part number for it. It's an adapter.
05-05-2015, 07:51 AM | #3 |
Lefty, I have the original round connector, on the dash wiring harness. The wiring had a short and burned all the way up to where the turn signal switch attaches. I am replacing the dash harness, but was wanting to keep the original curved turn signal switch connector. Just curious if anyone knows where to buy the pins that fit into the plastic connector?
05-05-2015, 02:58 PM | #4 |
I am not aware of anyone that makes a replacement connector. Are the ends on the wires ruined, or do you just need the plastic housing? If just the housing, I would suppose one could be removed from a good used original. The correct tool is needed to remove it or the wires so t stay in Place when reinstalling it. (Ask me how I know!)
05-05-2015, 05:18 PM | #5 |
The connectors that crimp onto the wires are ruined, as were the wires. The plastic connector is I'm great shape and I was hoping to reuse it. I've found a few connectors that look similar online, but haven't been able to verify if they are the right ones.
05-05-2015, 09:21 PM | #6 |
I realized my question wasn't super clear. I'm looking for the part number for the wire terminals that fit into the arc shaped connector. Probably a Pachard Delphi number from way back when. Any ideas?
