Old 05-09-2015, 06:45 PM   #1
Jonathans55
I really hate electrical. Help?
So I'm almost finished with my rewiring of my 55. Here is my issue. I have a left turn signal when my headlights are Off. A right turn signal when my lights are on. And when my lights are off the right selector switch my hazards activate. Ummmmmm not gonna lie I'm stumped. I thought wires on this bad boy were supposed to be easy lol.
Jonathans55 is offline   Reply With Quote
Old 05-09-2015, 07:53 PM   #2
OrrieG
OrrieG's Avatar
Re: I really hate electrical. Help?
Stock or after market column and turn signal switch? Which wiring are you using?
Old 06-03-2015, 09:59 PM   #3
_Ogre
_Ogre's Avatar
jonathan55 hasn't been back since he posted, but i'll ask again ^^
also what turn signal switch?
shop air compressor timer
Old 06-05-2015, 02:42 PM   #4
OrrieG
OrrieG's Avatar
I went overkill on the grounding, use an old #4 battery cable between bed, cab, and front clip to frame. Used stock battery braided cable neg to fire wall, fire wall to block. Grounds and wrong size (too big or small) have given me fits over the years.
Old 05-09-2015, 09:29 PM   #5
franken
Did you forget to ground the body?
All current flowing from a source has to flow back to it. Since the body and frame are part of the circuit, they have to be electrically tied to the negative side of the battery, as does the alternator case.
The big red/+ battery cable goes to the starter. The big black/_ cable goes to the block.
Then smaller wires ground the block to frame and/or body and there's often another small ground from the battery to a fender or core support. Then there are ground straps from the body to frame, etc.
When the truck was new there was no rust. Now there may be no or poor electrical connections.
Old 06-03-2015, 02:57 PM   #6
Coupeguy2001
Coupeguy2001's Avatar
you have the power wires reversed between the flashers and the turn signals.
The white wire in the column connector is the white wire from the stop light switch.
That is the power that is switched with the turn signal switch.
Coupeguy2001 is offline   Reply With Quote
Old 06-03-2015, 08:09 PM   #7
57chevyman
57chevyman's Avatar
sounds like it may be a grounding issue. try running a ground wire directly from one of the bolts on the tail light bracket to the frame where the bumper bolts on. the tail lights are self grounding thru the bracket, but if that ground isnt strong enough, a separate ground wire may do the trick.
or you have wires connected wrong.
or both LOL. i feel your pain. wiring lights can be frustrating
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
