05-13-2015, 01:11 PM | #1 |
fuel line
I have a 55.2 gmc with a camaro sub. Small block with a mechanical fuel pump. Does anyone have pictures of the fuel line routing? I concerned about header clearance. Any advice would be helpful. Thanks
05-13-2015, 01:36 PM | #2 |
Re: fuel line
Sounds like your tank is still behind the seat? Here is how I ran mine from tank at back, inside frame rail, to filter next to stock fuel pump. If behind the seat I would run the line tight against cab floor to frame, then inside frame to mechicanical pump location. If you are concerned about heat, wrap it with some header wrap.
