05-13-2015, 03:42 PM | #1 |
1964 C10 horn button removal - how to?
I have the simple round horn button and need to remove it to service the turn signal switch. I assume I can pry it off but don't want to break anything.
What is the best way to remove the horn button? also, once it is off what type of puller do I need to remove the steering wheel? thanks |
05-13-2015, 03:52 PM | #2 |
Check The Champ, Demonstrator
Re: 1964 C10 horn button removal - how to?
You just have to pry off the horn button. Rummer mounted, but I'd pull the ground wire first. No use loosing some hearing and pissing off the neighbors if it gets stuck.
After you remove the nut you might be able to just wiggle off the steering wheel. If not you can make a wheel puller with some flatstock and threaded rod. Some of the autoparts store will lend you a puller around here. The puller saves you a trip to the hospital for stitches when the steering wheel decides to let go. Lots of cheap shop manuals on Ebay that can help you out on jobs like this. You'll need a 63 Truck Shop Manual and a 64 Truck Supplement.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
08-21-2015, 09:15 PM | #3 |
Hey guys, I know this is an old thread but it's right up my alley. I need to fix the turn signal switch on my 62 and I don't have a manual yet. Once the wheel is off, isn't the turn signal right there? Or do you have to go further down? Thanks!
08-21-2015, 10:59 PM | #4 |
1961 crewcab
turn signal is right there.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-21-2015, 11:12 PM | #5 |
08-23-2015, 11:15 AM | #6 |
Jonz isn't the "switch" on a 62 down the column?
08-23-2015, 06:22 PM | #7 |
10-05-2015, 03:18 PM | #8 |
now my horn honks when I turn the wheel hard in my driveway to get out. It doesn't honk when I drive and make turns, only when I turn the wheel when it is not moving when I'm getting out of a tight spot. Any hints?
