Old 05-14-2015, 01:17 PM   #1
DustyNova
Caddy 500 in a 89 blazer with a gmc kodiak 5 speed transmission?
would this work?
DustyNova is offline   Reply With Quote
Old 05-14-2015, 02:05 PM   #2
bustedknuckles
bustedknuckles's Avatar
Re: Caddy 500 in a 89 blazer with a gmc kodiak 5 speed transmission?
With a little skill, money, cutting torch/plasma, welder, and grinder anything will work.
84 GMCummins
91 CCSB Dually
american squarebody association
bustedknuckles is offline   Reply With Quote
Old 05-14-2015, 02:23 PM   #3
bigblock73
yeller
bigblock73's Avatar
A hemi in a yugo will work...anything is possible with the appropriate amount of planning, commitment and craftmanship.
bigblock73 is offline   Reply With Quote
Old 05-14-2015, 03:20 PM   #4
Tom
driving is in my blood
Tom's Avatar
Your going to ask if every type of caddy v8 ever made will work in a blazer with any type of GM transmission ever made aren't you? This is alot of caddy will it work posts.
Old 05-14-2015, 03:42 PM   #5
kalbert
A SOHC 429 backed with a caterpillar hydrostat will fit. You can hook something up to everything and use it to power anything. You're limited only by time and money.
Is a 500 Cadillac and ZF 5 speed doable? Absolutely. Practical? Not in the least. Its not even on the "neat because its different" spectrum. Its on the "omg that was a lot of work for next to no purpose" spectrum. High on it. I think you ought to scrap the Cadilac boat anchor + oddball transmission ideas and go with something a little more mainstream. there's a reason you don't see many 500 Cadillacs. No need to learn first hand why.
You can do a 502 big block and a 4L80e for pennies on the dollar to what you'd spend on this weird Cadillac stuff and have 100x more realistic chances of success and happiness.
kalbert is offline   Reply With Quote
Old 05-14-2015, 03:53 PM   #6
Malo83
Cruzzzn' Vet
Malo83's Avatar
I would go for it, but go with an auto tranny, different is better instead of mainstream, still a lot of parts available for the caddy
http://www.bing.com/images/search?q=...ne&FORM=RESTAB
Malo83 is offline   Reply With Quote
Old 05-14-2015, 09:08 PM   #7
DustyNova
a caddy 500 is def not a boat anchor
Old 05-15-2015, 10:49 AM   #8
crashz
crashz's Avatar
The caddy big blocks work good if you are on a budget, use a modified TH400 with the Pontiac/Olds/Buick bell-housing and custom make very bracket and mount you need. If 4wd, the tranny needs a 4wd rear housing and tailshaft, which means a full dissection/rebuild.
No idea if the 5 speed would work or if you can find a flywheel for that caddy motor.
But...
I'm slowly learning the value of actually having the vehicle running and driving. As I get older, I'd rather be driving that blazer to the beach than crawling around trying to get a square block to fit in a round hole...
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 05-15-2015, 11:13 AM   #9
gmachinz
Caddy 500's are getting hard to find but NOT a turd BB that's for sure. 1970 was the highest rated year where they were rated at 375HP/500lbs. in stock configuration a comp. ratio was 10.25:1 for 1970 only. Yes, to build one isn't cheap beyond stock-therss a few companies dedicated to stroker kits for them-nobody makes any kind of performance head that I'm aware of-Edelbrock makes intakes for them....porting the stock heads and going with a stroker setup is the best you'll do with them-long rods and a heavy crank build a lot of torque but to go upstairs with them at all you really need modifications to the oiling system.
gmachinz is offline   Reply With Quote
