Old 05-15-2015, 03:44 PM   #1
DustyNova
olds 455 vs buick and pontiac 455s?
What is the stronger motor out of them i wanted to drop one in a 77 crew cab short bed k20 4x4 th400 tranny no motor 205 transfer case
DustyNova is offline   Reply With Quote
Old 05-15-2015, 05:31 PM   #2
TwoFiftyShifter
Re: olds 455 vs buick and pontiac 455s?
Ford's new Ecoboost V6 has all the stump pulling torque you need - and the fuel efficiency that puts a smirk on your face at the gas station.
Even if you end up disliking the motor, you still can say "That's not your ordinary 350 or 454 Chevy in there partner!"
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 05-15-2015, 06:50 PM   #3
jayoldschool
Moderator
If you're thinking BOP... the answer is Cadillac 500 ;-)
jayoldschool is offline   Reply With Quote
Old 05-15-2015, 09:06 PM   #4
DustyNova
what are ya retarded?
Old 05-15-2015, 09:11 PM   #5
enigma
I personally would go for the Buick 455
enigma is offline   Reply With Quote
Old 05-15-2015, 09:43 PM   #6
TwoFiftyShifter
Hey Sport,
You are posting multiple threads asking about pontiac, Cadillac and Buick engines on a Chevy truck thread.
Figured I'd throw out another engine that doesn't belong in a 4X4 Chevy.
1982 K10 SWB
Old 05-15-2015, 10:34 PM   #7
clinebarger
Hey Sport,
BOPC swaps in these trucks were once very popular, Just as....If not more than LS swap are today. An Ecoboost swap would be a lot more involved.
The Ford 3.5L Ecoboost is a offshoot of the Duratec POS with twin turbos & DI.
Have you ever performed a Ecoboost swap before.....Slick?
clinebarger is offline   Reply With Quote
Old 05-15-2015, 10:48 PM   #8
69heavychevy
69heavychevy's Avatar
Why not just drop a 454 and call it a day...
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 05-18-2015, 11:17 PM   #9
MikeB
MikeB's Avatar
Seriously??? Can you even begin to imagine all the electronic components you'd need, and a way to mount the intercoolers, not to mention a megabucks adapter for the trans? It would make an LS swap look like a walk in the park. And it's a FORD.
On the original topic, Cadillac 500 and Pontiac 455 engines probably have the best parts availability.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-18-2015, 11:34 PM   #10
mud.man.rj
mud.man.rj's Avatar
The Caddy or Olds would have awesome train like torque all day too.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 05-15-2015, 09:11 PM   #11
franken
I'm more partial to Pontiacs after Chevy but that's not objective.
Is the th400 a BOP bolt pattern? If not you may need another case.
Did they make short crews in 77, least of all in 3/4 ton? Seems unlikely.
Old 05-16-2015, 08:08 AM   #12
95 S_Trucker
95 S_Trucker's Avatar
There is a reason the op is getting these type of responses. This is the 8th thread he started in the last 2 weeks about swapping a Pontiac, Olds, or Cadillac motor.
http://67-72chevytrucks.com/vboard/s...archid=4786393
95 S_Trucker is offline   Reply With Quote
Old 05-17-2015, 12:10 AM   #13
DustyNova
id lol if someone finds a video with a ford v6 in a old chevy lmao
Old 05-17-2015, 12:21 AM   #14
Barbecue
Olds 455 engines that were from Toronados were incredible engines. I believe they were equipped with bigger than normal lifters and had more nickel in the block. 425 Toronado engines (earlier; I beleive '66 and '67) were incredible as well. These engines were often coveted for marine and other heavy duty or performance applications.
Barbecue is offline   Reply With Quote
Old 05-17-2015, 02:00 AM   #15
Titomars
Titomars's Avatar
To go along with all of this the Olds 455 was also the only engine mounted in the GMC motor Home. Basically a Toronado drivetrain.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 05-17-2015, 12:34 AM   #16
TwoFiftyShifter
https://youtu.be/kQZV6q00sUc
1982 K10 SWB
Old 05-18-2015, 03:52 PM   #17
Jonlopes
I would go with the olds 455 out of all of those. It is very reliable, makes big power and gets decent mileage.
The buick motor seems on paper like it is made for trucks with 510 foot pounds of torque at like 2000 rpm but they had oil issues, the oil pump was more sensitive to wear than other brands. if you go buick I would change out the timing cover hopefully for a new one (the oil pump is in the timing cover). Also the distributor is in the front making it more vulnerable to water splashing than the others who put it in the back.
Pontiac engines make great power I have had several and have been happy with them.
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
Old 05-18-2015, 07:37 PM   #18
Titomars
Titomars's Avatar
Interestingly enough is that it was the Pontiac V8 that was a truck engine for a time. They were used in GMC's in the later 50's. Buick 350's were used in Kaiser Jeeps in the late 60's.
Personally if I was to go with a BOP engine I would choose an Olds 455. Pontiac hard parts are getting scarce and Buick T/C covers are even worse because of the oil pump issue.
Old 05-18-2015, 10:45 PM   #19
Malo83
Cruzzzn' Vet
Malo83's Avatar
Pontiac/Olds 455 in an S10
https://www.youtube.com/watch?v=1lmtA6vDNxA
https://www.youtube.com/watch?v=6FHAnvXNOlQ
Malo83 is offline   Reply With Quote
Old 05-18-2015, 10:55 PM   #20
mud.man.rj
mud.man.rj's Avatar
Just remember it cost more $ to go odd ball Bop than Chevy, now Fords need a good Chevy motor not F**d in a Chevy..
5.0 4spd std.
7" lift w 35's.
Old 05-19-2015, 12:00 AM   #21
nonstop
Man up and go with a Detroit 4-53 or 6v71t! Are you looking for unique or longevity? This covers both!
nonstop is offline   Reply With Quote
Old 05-19-2015, 12:10 AM   #22
rcrahn
rcrahn's Avatar
I love Pontiacs, have a 1969 Firebird with a full roller 462....As others have said, Pontiacs like mine are just more expensive to build than a Chevy.
I looked at the OP. I would like to throw out another idea - why not an 8.1 L?
In that 77 Crewcab it would be a stump puller....
rcrahn is offline   Reply With Quote
Old 05-19-2015, 02:28 AM   #23
rich weyand
rich weyand's Avatar
The Buicks had a lot of torque, but they would burn valves in sustained high load, like pulling a trailer in the mountains.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 05-19-2015, 01:22 PM   #24
hatzie
Moderator
hatzie's Avatar
472 Caddy. Stump pulling torque and the 500 is getting harder to find.
Quoting an acquaintance, that had one in a 77 3/4 ton GMC, about towing an Airstream Sovereign up the Grapevine. He said "It didn't feel like she was towing a thing. I just put my foot on the pedal and she picked up speed." That's a 6% grade folks.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-19-2015, 10:58 PM   #25
greg64
greg64's Avatar
I think all of these b-o-p-c swaps are neat, and I researched it myself. It's definitely possible, but the transmission options seemed limited, compared to a Chevy. Th400, no problem. Overdrive possible with a 200-4R, but I wanted stick, and that gets messy. For example, some of these engines don't have the crank drilled for a pilot bearing. Ya, it can be added, but that's a lot of work. I'm not in love with bellhousing adapter plates either. Stock bellhousings exist, but are likely tricky to find and are setup for a Muncie M20.
One thing that seemed clear is to find the one vendor that exists today that specialize in that particular engine. They all have one, and no doubt that outfit would be a fountain of knowledge and parts.
Other interesting tidbits; the Buick is 100 lbs less than the others, nearly the weight of a SBC. The caddy is light for it's displacement. The Pontiac blocks are all externally the same, so that might help with headers, etc. the pontiacs also had a long run, relative to the others (the engine design, not the 455 specifically). The Olds seems to be the torque king if we ignore the caddy. Some of the engines need oiling system modifications if you're going to rev the snot out of them, others don't. It's all quite interesting. I wish the General was still making all sorts of engine designs today, but it's understandable why they don't.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
