05-15-2015, 11:57 PM | #1 |
Frame twist
After removing my bed I'm thinking my frame is a bit twisted. Looks to be about 1-1.5" lower on one side than the other, only in the rear. No buckling that I can see.
So I dropped by a frame and suspension shop to ask a few questions, but the answers didn't seem to make much sense. Does the body/bed have to be on the frame? They said yes as they won't be able to make everything line up without it. I figured if it's a simple twist (which I can't guarantee, but it appears to be) they could just use the factory manual spec and untwist it. Second question, which I didn't ask because I know their answer, is it possible to untwist the frame at home? Any possibilities? I figure it would be worth the $300-400 to have it done, but considering the body isn't straight to begin with it doesn't make much sense to make it line up with the body. And I am a ways off putting it back together anyway.
In the garage: The project - 1968 C10 Short box The hauler - 1994 K1500 Silverado Z71 - Sold 2015 Colorado Z71 |
05-16-2015, 06:16 AM | #2 |
Re: Frame twist
I would leave it to a pro so its done right.
05-16-2015, 09:21 AM | #3 |
Re: Frame twist
What body issues do you have and what's your plan for future work? I ask this because if you have rusted cab supports and smashed cab and radiator support bushings it's not the best idea to have a shop basically align the body by twisting frame. I would make sure my cab supports and rad support isn't rusted, replace the bushings, then pay the pros to make it happen. I wouldn't personally mess with it. I'm only 33 but I've learned over the years sometimes you just have to buy new and pay the professionals, sometimes it's worth it.
05-16-2015, 07:15 PM | #4 |
Re: Frame twist
The frame seems solid, just a slight twist. Nothing rotted or rusted through.
There's plenty of body work to be done. It seems absurd that the body must be on the frame when the body just sits on the frame and the measurements from the frame to the ground are standard. I agree to let pros handle things, I also agree that sometimes pros won't give straight answers to some random person. Seems like they're over complicating it.
05-16-2015, 08:07 PM | #5 | |
Re: Frame twist
Is the frame on a surface plate, or sitting on the suspension and wheels? It the latter, then just shim the suspension to square it back up. The body doesn't provide any structure to a pickup, because the cab and box are separate. Not like a passenger car, where you gain some torsional rigidity from the body. It's very apparent if you ever have to opportunity to see a loose pickup frame vs a loose passenger car frame. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-16-2015, 08:23 PM | #6 | |
Re: Frame twist
I've heard that the suspension could just be collapsed on one side, so I figure once I get it on the stands and leveled I'll know for sure. This image makes it seem like it would be pretty straight forward to measure and square everything up. Maybe on a plate where I can secure it and use a press or something.
05-19-2015, 04:59 PM | #7 | |
Re: Frame twist
05-19-2015, 06:12 PM | #8 |
Re: Frame twist
It is. And it is on our trucks too. At least on mine. I thought something was wrong till I also saw it on other trucks in pictures of frames and things line up fine for track bar bracket etc.
1970 Shortbed 2wd C-10 |
05-18-2015, 12:58 AM | #9 |
meowMEOWmeowMEOW
Re: Frame twist
To clarify, you aren't concerned that the frame is twisting under accel, just that at some point a situation occurred that twisted it? It didn't seem like we were talking about a 950hp front-end lifter, but wasn't sure haha.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
05-18-2015, 09:46 AM | #10 | |
Re: Frame twist
Seems like it was hit on the rear passenger corner at one point.
05-19-2015, 07:29 PM | #11 |
meowMEOWmeowMEOW
Re: Frame twist
It is on my '66. I stared at it with a beer in my hand for a good half an hour before we found our old service diagrams and sure enough, its like that in the factory print.
05-19-2015, 09:24 PM | #12 |
Re: Frame twist
If the body isn't on the frame when the frame is straightened the cab/bed will still be tweaked and may not fit when you go to put it back on.
05-20-2015, 01:40 AM | #13 | |
meowMEOWmeowMEOW
Re: Frame twist
If the cab supports themselves didn't rip/sag/rust/bow, then it should still be able to fit back on. He could go buy a brand new built chassis and toss his cab on, either way the panels will have to be refit, and the cab supports may/may not need to be shimmed.
05-20-2015, 07:26 PM | #14 | |
Re: Frame twist
SOP at a bodyshop is to pull the frame with as much on the vehicle undisturbed as possible. This way the parts attached to the frame get bent back where they belong. So the OP sold the truck because the frame might be twisted? Seems harsh. |
05-20-2015, 10:54 PM | #15 | |
Re: Frame twist
05-21-2015, 02:59 AM | #16 | |
meowMEOWmeowMEOW
Re: Frame twist
If the cab had sagged so much that it couldn't be put on a rottiserie or something, then it was a lost cause WAY before we ever started.
05-20-2015, 10:39 AM | #17 |
Never Ending Projects
Re: Frame twist
Yes, that cross member that is at an angle is to help prevent "racking" of the frame. GM engineers were smart cookies.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-20-2015, 03:03 PM | #18 |
Re: Frame twist
Well, as of this afternoon the twisted frame won't be my problem anyway. Truck sold and will be towed away this afternoon/evening.
Sad to see it go, but happy to have it out of the way. Thanks for all the input everyone.
05-27-2015, 11:56 AM | #19 |
Re: Frame twist
Could be it is just sitting higher on one side and if it is not suspension caused it could be that it was overloaded at one point and could be corrected by unriveting the cross members to let the frame drop back into position and then reattaching or replacing the crossmembers. Good time to install a rear gas tank too while the rear crossmember is out
