05-16-2015, 07:58 AM | #1 |
Diggin The SquareLife
shaved firewall
ok ima be shaving my firewall here soon, an I wana know what have everyone has done with the fuse block on the firewall by the steering column? please share pics an info or links. thanks
05-16-2015, 03:21 PM | #2 |
Re: shaved firewall
I am interested in seeing what people have done too.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
05-16-2015, 07:26 PM | #3 |
yeller
Re: shaved firewall
I built a box to cover my Painless 73-87 harness in my old 73. I actually sold these too for a while, but no longer do. Here are some pics before paint...it was painted body color after the photos were taken, and I changed the design so all the wires exited the bottom and were covered in loom. Harness headlight section ran inside the drivers fender to the core support, completely out of sight.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
05-16-2015, 11:09 PM | #4 |
Re: shaved firewall
looks good...might have to try an fab something up like that
05-16-2015, 11:47 PM | #5 |
Re: shaved firewall
Or get a universal wiring harness and mount the fuse block anywhere you want to put it.
05-17-2015, 07:58 AM | #6 |
Re: shaved firewall
I don't think im going to go that way....pretty sure there is a few more options
05-17-2015, 09:04 AM | #7 |
Re: shaved firewall
speedway has a nice 21 circuit harness for 164.00. it doesn't go thru the firewall like that. then you can just route your wires werever you want them. more work to rewire though. just depends on how smooth you want it.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
05-17-2015, 11:48 AM | #8 |
Re: shaved firewall
05-18-2015, 02:48 AM | #9 |
Re: shaved firewall
what ya think bout just extending the wire....maybe just as much work as rewiring it..im jus gonna have the brake booster/master cylinder on the fire wall
05-18-2015, 02:51 AM | #10 |
Re: shaved firewall
this is a shaved firewall
05-18-2015, 12:26 PM | #11 |
Re: shaved firewall
I have a buddy that shaved the firewall in his 70 C10. He cut the section out of the fire wall where the bulkhead connector mates up to the back of the fuse block and welded that piece inside the truck. Then he patched up the hole with sheet metal and routed all of the wires out the side of the fire wall and into the cavity of the fender. I know that his generation of truck has more space between the side of the fire wall and the fenders than our generation does, so you could run the wires down through the lip of the fire wall (like the parking brake cable routes) and that should hide your wires between the fire wall and the inner fender. Just an idea.
86 Chevrolet K10 350/SM465 Frankie SOLD 1995 GMC Yukon GT SOLD 1996 GMC Yukon GT 2010 Suburban 1500 4x4 5.3l/6L80e. Sold 2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e |
