Old 05-17-2015, 11:07 AM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
fuel tank filler neck
Anybody know how the fuel tank filler neck is attached to the tank on a 72. I bought a aftermarket tank an it only has a stub. I have my old tank out and the neck unbolted but it won't come off. I assume this means it is probably soldered on. I guess i could just cut the curved portion off and get it welded to the stub.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 05-17-2015, 01:12 PM   #2
briank
Re: fuel tank filler neck
Soldered ...and a lot of people use the old one on their new tank because the repops arent right.
briank is offline   Reply With Quote
Old 05-17-2015, 02:22 PM   #3
jaros44sr
jaros44sr's Avatar
X2 use a chisel to start the cut and then follow up with tin snips. mine had the two bolts and soldered, replacement tank is brazed on, I got it off by using a dremel cut off wheel, since the new tank never had gas in it, I wasn t worried about sparks blowing me to kingdom come
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-17-2015, 04:47 PM   #4
72BLAZERDUDE
where are you cutting ?. Did you get the whole neck off including the flange. Then how did you attach the new one ?. I have a neck off of a old tank that I cut off with part of the tank still attached so that will be my donor.
Old 05-17-2015, 07:30 PM   #5
jaros44sr
jaros44sr's Avatar
I ground down to the gold color of the brazing, though the sheetmetal of the stub neck, and then ground the remaining braze as flat as I could. I had to cut some of mounting nuts off. I then used them as studs to solder the oem neck on
just unsolder the oem neck from the tank metal that is left on the neck
SAFETY FIRST
AS usual, off topic
Jim
Old 05-18-2015, 11:35 AM   #6
1tuff71
1tuff71's Avatar
I know all I had to do with my old tank was take a propane torch to it where it attaches to the tank and the solder melted off and the neck came right off. Had a radiator shop braze it to the new tank.
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........
1tuff71 is offline   Reply With Quote
