Fuel Line - Diesel
is the standard Zinc (Steel) fuel line OK for diesel? Described as "OE-type double wall copperized steel tubing coated with galvanized zinc for superior rust protection". Much cheaper than Stainless. In Texas so no beaches or raod salt.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and 47RH AOD transmission http://67-72chevytrucks.com/vboard/s...d.php?t=640042 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: Fuel Line - Diesel
I'd say so. I've used regular new brake line for running fuel lines and pick up tubes before. None of those trucks ever had an issue and they see road grime and stuff.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
The only line I have been told you don't use for diesel is pure copper. They say it will cause a chemical reaction and mess up the fuel system. I do not know if this is true just what I have been told. I have seen many old antique diesel with copper fuel lines though.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
