![]() Join Date: Sep 2007
removing spray on liner
so i picked up a great 67 passenger fender. only one problem. it has a medium coat of rattle can spray on liner on the inside . Grrrrrrrr
so any of you guys know of a quick way to get all this crud off?
1967custom |
Re: removing spray on liner
Grinder + wire wheel cup.
If you don't mind repainting, trot down to your local Home Depot and pick up a quart of this stuff. Just like Superman in a can:
on my way fitz. thank you. its primered so no paint to damage.
a wire whell would just take way too long with all the little crevices on the back of these fenders. thanks!!
1967custom |
Michael, Make double barrel sure that you get all I mean ALL of the stripper off or else it will seep into the new finish and also leak from the seams onto the new finish. Jim
Try easy off oven cleaner, ive heard that works.
scraper and a propane torch is what I have used on undercoating just soften it up with hte heat then use the scraper to scrape it off. Then you can hit it with what ever stripper you want or get it blasted.
