05-20-2015, 12:00 AM | #1 |
Door weather strips for 71 Chevy - Success stories
Stayed on, great fit, door closes correctly.
I've looked and really, the most convincing success stories I've seen are one guy who took them off a Honda, and another who spent the entire day gluing the seals on (not sure part mentioned). Anyone have a success story they'd like to share? What parts did you use? Incidentally, I've bought a ton of NOS, and only two were returned. They were the "LH" and "RH" weatherstrips "3951813-4". Quotes have "special" meaning.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-20-2015, 02:46 AM | #2 |
US Army Veteran
Re: Door weather strips for 71 Chevy - Success stories
Mid to late 90s Dodge Dakota or the smaller trucks. I've read about these many times here. Last year, while on a visit to family, I took some time out to go to a good parts yard that I knew still had some old 67-72s.
Picked a few wiper motors, the ventured over to the dodge area and picked out a good set of door seals. They fit my truck great. I had purchased the famous precision "clip on" from a vendor here, but there was a physics issue in getting those door shut! No amount of adjustment would even get the doors close to shutting with the new ones.
1972 C10 Highlander - The making of a daily driver |
05-20-2015, 09:37 AM | #3 | |
05-20-2015, 09:53 AM | #4 |
This is what I used on recommendation from this board
I ordered a brand new set from Hondapartscheap.com P/N 72315-SVA-A01ZA for the right side. P/N 72355-SVA-A01ZA for the left side. works great ,, they are allitle big for the space but the bottom plate at the rocker smooths out where it wants to bunch up , hardest part is getting all the old glue and strip off ,, truck has much less road noise now ,, and they clip on and off easyly for painting and body work
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
05-21-2015, 01:03 AM | #5 | |
05-20-2015, 11:13 AM | #6 |
used dodge dakota. $5 at my local pick and pull. a bit of castrol super clean and some hot water and they look brand new. fit like they were made for these trucks.
05-21-2015, 01:04 AM | #7 |
Huh........Dodge and Honda.
05-20-2015, 11:27 AM | #8 |
Moderator
86-96 Dodge Dakota. Plentiful at the junkyards, cheap, fit like a glove, clip on-no glue. Win win win all the way.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-20-2015, 12:14 PM | #9 |
out in Ventura CA, no good part yards. Do you happen to have a part number for the Dodge ones so I can get them new?
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
05-21-2015, 01:05 AM | #10 |
Thanks. I'm thinking 86-96 Dodge Dakota.
05-20-2015, 12:26 PM | #11 |
i used a set from a 88-98 chevy full size and these worked well and since they were used they were soft and no door closing issues at all. they were a little long but i cut off about a foot from the bottom and the door seal covers the cut well
1967custom |
05-21-2015, 01:09 AM | #12 |
I used GMC Paul's clip on (avoid glue!!) VERY high quality, but take forever, I mean forever, to break in/compress. I adjusted the hinges and latches outward to try to compensate without being unsightly, and they STILL are too full to shut the door with the good old solid clunk, have to slam. It's been somewhere between a year and a half and two years. SO, next time for me - will be Dakota wx strips.
05-21-2015, 11:28 AM | #13 |
The honda door weatherstrips require a stout pull ,, not a slamm , they seem to be the perfect thickness
05-21-2015, 03:14 PM | #14 |
I brought a cheap set off year one and just glued them on iv had no problems with shutting the doors
"I ain't got no time for side tracks!" 69 R/T Charger 72 C10 Chevrolet 85 302 Jaguar 99 955 Daytona 10 1050 Speed Triple |
05-21-2015, 04:31 PM | #15 |
anyone have a pic of the stock seals compared to the dak seals on their truck? I'm very interested and will be doing this very soon.
05-21-2015, 04:41 PM | #16 |
I would like to see what the clips look like on the dodge seal. Anyone have a pic of that?
05-22-2015, 07:56 AM | #17 |
05-22-2015, 10:02 AM | #18 |
So what are they talking about when they say the dodge one has clips?
05-22-2015, 11:12 AM | #19 |
Not the best pictures, but these are the Dakota weather strips installed. As Jocko described, the "clips" are enclosed within the rubber.
05-22-2015, 10:49 AM | #20 |
It just means that there is metal embedded in the rubber that "clamps" onto the raised crimp seam. No way to actually see them without tearing the seal apart. It really is the best way to go and allows the seals to be re-usable. They're sturdy and don't fall off though.
05-22-2015, 11:13 AM | #21 | |
05-23-2015, 08:55 PM | #22 |
Unless I'm mistaken, the Dakota door seals aren't molded like the GM parts for the upper inside corner, correct?
If I'm on the right track, the correct years (Dakota) are 87-96.
05-23-2015, 10:30 PM | #23 |
Moderator
They are not molded but they conform just fine.
05-23-2015, 10:48 PM | #24 |
Correct. But, as leddzepp said they fit fine. Here are a couple pictures of mine. Inside and outside.
05-24-2015, 11:30 AM | #25 |
Are you guys using new dakota seals or pulling seals off junk trucks and reusing?
Opportunity is missed by most because it is dressed in overalls and looks like work. - Thomas Edison |
