Old 05-22-2015, 02:28 PM   #1
BraydenO
Inner door handle question
Trying to get off my passenger inner door handle I removed the clip and it won't pull off... I did the driver side and it came off easily same with both window cranks. Ive been shaking it, I've tryed shaking and jiggling it, and I've tryed shaking jiggling and beating it, and the bugger still won't get off. Any suggestions?
BraydenO is offline   Reply With Quote
Old 05-22-2015, 02:33 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Inner door handle question
try spraying a little soapy cleaner on the handle like purple power. where it meets the crank and let it soak for a few minutes
1967custom
michael bustamante is offline   Reply With Quote
Old 05-22-2015, 02:56 PM   #3
BraydenO
I threw some deep creep sea foam on it and still nothing. Any other tips would be appreciated!
Old 05-22-2015, 04:12 PM   #4
7tee
7tee's Avatar
Well knowing me I would probably spray some liquid wrench in there and let it set for awhile. Then I would hit inward on the center with my fist then try to pry it off or anything else. I will not let it beat me...
7tee is offline   Reply With Quote
Old 05-22-2015, 04:10 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
It's a very long shot, but could there be a second clip jammed in there?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-22-2015, 04:33 PM   #6
michael bustamante
well if worse come to worse and it breaks off i have another one for ya
1967custom
Old 05-22-2015, 06:34 PM   #7
BraydenO
Well deep creep has been there a couple hours and still nothing I did look for a second pin and there was nothing I've tried beating it towards the door with a mallet too and outwards off of the handle. I do have a parts truck tho thanks for the offer bustamante! If I take a die grinder to it does anyone know if those splines are easy to replace?
Old 05-22-2015, 07:53 PM   #8
AirSpeed
AirSpeed's Avatar
I used a slide hammer on one that was stuck, came right off. The splines in the handle had corroded. The splines on the regulator were fine once I cleaned them up.
AirSpeed is offline   Reply With Quote
Old 05-22-2015, 11:22 PM   #9
michael bustamante
I was just going to suggest a slide hammer too
1967custom
Old 05-27-2015, 11:34 AM   #10
Baddflash
Just had this same problem pulling the door panels off my cousins '72 parts truck. The drivers side door handle would not come off. Thought we could just brake or strip the handle out but in the end the whole shaft broke off in the handle.
Baddflash is offline   Reply With Quote
Old 05-27-2015, 11:42 AM   #11
cooperhw
cooperhw's Avatar
I suppose if worse came to worse you could use a grinder and just remove the outer shell of the handle. It's just pot metal and should grind away pretty easy. I would protect "EVERYTHING I DIDN'T WANT RUINED" and cut it off. Once the outer handle removed you could probably cut the handle off the splines carefully with a dremmil tool.
It's just pot metal and easily replaced.
Just a thought.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
