05-29-2015, 10:01 AM | #1 |
Gas Gauge Not Registering
I need some advice on an ongoing issue I'm having with my gas gauge. I have replaced my send unit - twice - and completely gone through a troubleshooting guide that I got off this forum, but still have a gauge that only ever registers a maximum of a quarter tank. Since I had a bad replacement I metered the send unit before I installed it & all was good. I have removed the send wire - gauge registers full. Grounded the wire at the tank - gauge goes empty. Metered the wire from tank to fuse box & from fuse box to gauge - all good, have 12V on other terminal of gauge. pulled out the instrument panel & checked the printed circuit board - cleaned all contacts, replaced burnt out bulbs. I don't know what I'm missing, but it has to be something as it still is not working. Help please !!
05-29-2015, 10:22 AM | #2 |
Msgt USAF Ret
Re: Gas Gauge Not Registering
Pull the sending unit out of the tank and with the sending unit wire connected, and a jumper wire from the mounting flange to a good ground , move the arm up and down with the key on. Watch the gauge for travel from empty to full and back. If you get the full travel you may have a restriction in the tank keeping the float arm from moving through it's full travel. If you still only get 1/4 of a tank then you probably have a bad resistor on the back of the gauge.
Tom-TBone here on the forum has some and he does a fabulous job with the gauges and clusters. He may even see this thread and jump in.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-29-2015, 10:25 AM | #3 |
Thanks for the tip - I'll give that a try this weekend hopefully!
05-29-2015, 10:35 AM | #4 |
Mine did the same thing after I replaced the sending unit. Gauge worked fine before. I suspect it's the float but I'm not sure how to fix it without putting in another sending unit which will likely have the same problem.
Hopefully someone has some suggestions as I suspect yours is the same problem. |
05-29-2015, 11:25 AM | #5 | |
Junior Member
Thanks, Gordy
05-31-2015, 12:40 AM | #6 | |
Posted via Mobile Device |
05-31-2015, 09:50 AM | #7 |
I had that with my 70 back in the 90's. I couldn't find a replacement so I just lived with it, never ran out of gas. That's what was great about having the tank in the cab, you can hear how much gasoline is in the tank.
"You gonna pull them pistols or whistle dixie ?" |
