Old 05-29-2015, 12:56 PM   #1
JimmyCriswell
Advice on 350 Crate
I have a 35 GM Goodwrench Crate that appears to be all stock in a 68 C-10 longbed. I know the engine was replaced but I have no idea how long it has been in the truck or how many miles. Did compression check and had 2 cylinders with 0 compression. Starting opening the motor up and found 2 broken push rods. Cam appears ok as lifter travel was good. Exhaust and intake valves on 3,5,4,6 were white and when passenger head was pulled, number 4 had a buildup of oil on top of piston.
Heads going to machine shop to check. Looking for cam advice for an otherwise stock motor. Can anyone recommend a place for good rockers, pushrods, good but inexpensive gasket set and plugs.
Any other things I should check for? What about a good quadrajet rebuild kit. I think the fuel bowls were leaking and have caused the rings to wash out some.
Jimmy
JimmyCriswell is offline   Reply With Quote
Old 05-29-2015, 01:24 PM   #2
MARKDTN
Re: Advice on 350 Crate
Northern Auto Parts has cheap parts and gaskets. $219 master kit for 350.
http://www.northernautoparts.com/Pro...?ProductId=148
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
