Old 05-30-2015, 04:26 AM   #1
Crazy Rusty
Crazy Rusty's Avatar
Question Fuel Hard Line for rear mounted tank
Putting in a bed tank in the 62 C20 but didn't think of the fuel lines until tonight.
Has anyone used inlinetube.com for this? I've seen it referenced in at least one post but not sure if this is the way I should go. They say the fuel line is just for the 1/2 ton but I figure it should work fine for the 3/4.
Crazy Rusty is offline   Reply With Quote
Old 05-30-2015, 12:22 PM   #2
MisterC
MisterC's Avatar
Re: Fuel Hard Line for rear mounted tank
I believe that is just for the replacement of the factory portion, but I'm anxious to see responses as I'm getting ready to install my boyd tank.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 05-30-2015, 12:43 PM   #3
Crazy Rusty
It seems like I could buy this from summit - http://m.summitracing.com/parts/sum-220256 but it's coiled and i don't know if I have the skill to get it right nor the tools to do any flaring but I guess I wouldn't need to flare it, just secure the rubber line at each end.
Old 05-30-2015, 12:53 PM   #4
oldtrux
oldtrux's Avatar
The inline kit is for factory tank.you can buy 6' lengths of stainless 3/8" tubing.i invested in a rigid flaring tool and got a bender from inline.used an fittings.worth the small investment imo.did a bunch of other things as well,fuel pump to carb,pcv etc.will post pics later
oldtrux is offline   Reply With Quote
Old 05-30-2015, 01:54 PM   #5
MisterC
MisterC's Avatar
Pics would be great! I bought the bender when I did the dual master cylinder conversion, but I held off on the flaring tool. Looks like it's time. I too would like to customize my pump to carb line and some others.
Thanks.
Old 05-30-2015, 06:50 PM   #6
oldtrux
oldtrux's Avatar
Old 05-30-2015, 07:27 PM   #7
oldtrux
oldtrux's Avatar
Old 05-30-2015, 08:01 PM   #8
gimmy 64
i have a fuel pump.filter and fuel line 3/8 and all of the fittings . if someone is interested. was going in my truck but it was sold. pm me for more imfo and pictures if you want
gimmy 64 is offline   Reply With Quote
Old 05-31-2015, 12:38 AM   #9
Captainfab
60-66 Nut
Stainless is definitely the best way to go. But you can also use the straight length of coated steel line found at your local auto parts supplier along with some couplings. You can pickup one of those inexpensive tubing benders at HF as well as many other stores.
Old 05-31-2015, 12:33 AM   #10
Heater63
Heater63's Avatar
I bought a roll of aluminum tube and ran/built/flared my own. Don't forget to put a vent tube on the tank. Make a 360 degree loop in the vent.
292 + TKO500
Heater63 is offline   Reply With Quote
