05-30-2015, 02:06 PM | #1 |
Help-4L80e not shifting
Got a 4L80e trans 4x4 and the codes that came up was 0650 and 0654. The problem is when put in to gear slow to go in gear and will not shift. Fluid level is full and trans was rebuilt before installing. Have noticed once the truck does get warmed up that it take longer to go in gear and will have to rev up to get in gear.
Ralph L. Jasper 69 4x4 Suburban PTO winch(NAVY) 13 GMC Ext cab 12 Ford Fusion SE(wife) MAI Interior shop |
05-30-2015, 02:54 PM | #2 |
meowMEOWmeowMEOW
Re: Help-4L80e not shifting
Thats a powertrain control MIL and a speed input control MIL.
Doublecheck the wiring connections between the ECM and the trans, look for pinched wires or missing grounds. Verify that there isn't fluid leaking through the internal-to-external wiring harness on the side of the trans (it can leak into the weatherpak and cause false signal grounding internally). A ton of the ECM external functions are switched on the ground side, so a missing/bad ground can cause faults in multiple areas at the same time. I'd start there, and also verify that you have your brake/tcc switch hooked up.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
05-30-2015, 03:01 PM | #3 | |
05-30-2015, 06:29 PM | #4 |
meowMEOWmeowMEOW
I'd go laptop-open before I went pan off. You can manually manipulate the solenoids and check for fail conditions within the tuning suites. Troubleshooting there will give you a better idea of what to dive into. Unfortunately with trans failures, unless its an obvious fluid blockage or mechanical failure, you won't have the easiest time "Seeing" the problem.
Who did the tuning, and/or do you have EFI/HPT to troubleshoot with? Just for funzies; disconnect the battery, disconnect the ecu, have a beer, then reconnect them both. On a cold/blind start, do these codes pop up immediately, or do you have to be driving/shifting to cause the MIL's to pop up?
05-30-2015, 07:25 PM | #5 |
Are you getting ISS & VSS signals to your PCM?
Where are you getting the VSS signal at? The Transfer Case? As for slow engagement, Does the unit have a warranty? Last edited by clinebarger; 05-30-2015 at 11:31 PM. |
05-30-2015, 10:45 PM | #6 |
Has warranty so what are you thinking? I was told to try the pressure solenoid but my other trans guy thinks it something with the pump.
05-30-2015, 10:39 PM | #7 | |
05-31-2015, 12:19 AM | #8 | |
meowMEOWmeowMEOW
When you put the new speed sensor in, you might need to reset/clear the code or do a few on/off cycles to get everything to talk correctly. As for the 02 sensors you mentioned, if they were turned off in EFI live but the MIL wasn't turned off, then you can be getting a false MIL (but it wouldn't be anything related to the trans problem, just another thing I noticed)
05-31-2015, 11:07 PM | #9 |
You stated "the codes popped right up" If this is the case you have circuit related issues! The controller looks at circuit integrity on key up, and the condition isn't correct right then, before you road test it. I will use this as an example; say a controller turns on a light and turns it off by applying a ground to the circuit. 12 volts positive comes from a fuse, through the bulb filament and then over to the controller. The controller MUST SEE 12 volts on the circuit before it will take it to ground. Fuse blown, bulb filament broken, etc, and 12 volts (+) isn't available at the controller, hence a trouble code related to the light bulb would come up right away. Maybe that will help, but I would dig into the trouble codes first and know it forward and backward, and check it live by probing with a very good digital volt ohm meter. Good luck, Brian F.
06-02-2015, 06:49 PM | #10 |
Checked wires, connections, ohmed wires and soliedds and vSS and everything to deal with trans. Pulled pan and found a loose valve body. So started checking all the solenoids and tracing wires to check for anything. Put everything out of my other trans I pulled last week that was running and back together. The only thing changed was I have a strong reverse and a lot of black sut in the pan, the warmer it gets the worse it gets. Out it comes and really don't know the problem with the trans now.
06-29-2015, 06:10 PM | #11 |
Back at the transmission shop and fully rebuilt again with loose bolts on the valve body. Now they are saying that the everything is working manual but will only shift 1st to 2nd and will not shift anymore. They are trying to tell me that I need a TCM and the ECM will not run the trans with a 5.3, only with a 6.0. Looking for Ideals or what to do next?
06-29-2015, 07:16 PM | #12 | |
Even if you had a 4L60E program loaded, Codes would set, Trans would go into Limp Mode & 2nd gear would be the only forward gear. Any active transmission codes? ISS & VSS are functioning? See if the TCM is commanding 3rd gear with a Scanner.... |
06-29-2015, 07:21 PM | #13 | |
06-29-2015, 10:08 PM | #14 | |
Transmission or Transfer case??? If you are trying to use the Transmission VSS location on a 4wd 4L80E.....GM did not press a Output Tone Wheel on the Output Carrier on 4wd 4L80E's, However the Parking Pawl Lugs are right next to where the Tone Wheel would be, This would give a false reading to the PCM & result in VSS signal drop-out! Pictures comparing the 2 Output Carriers. |
06-29-2015, 10:20 PM | #15 | |
The trans guy said that there is a tone ring in the trans, so he's mistaken from what I'm understanding? Makes more sense, Thanks Solution??
Ralph L. Jasper 69 4x4 Suburban PTO winch(NAVY) 13 GMC Ext cab 12 Ford Fusion SE(wife) MAI Interior shop Last edited by engairuph; 06-29-2015 at 10:26 PM. |
06-29-2015, 08:55 PM | #16 |
meowMEOWmeowMEOW
Depends on what ECM your using. IIRC the e38 pcm's use a TCM because the trans drivers aren't integral to the pcm board. Then GenIII ECM's should control the 4l60/65/70/80e
07-10-2015, 07:04 PM | #17 |
I'm still having a issue getting my 4L80e to shift. I have a 2005 5.3 and a 1997 4L80e in a 69 4x4 suburban. Transmission guy that built trans says it not compatible and has to have a different computer. BP sent me a different computer and still the same. Changed the manifold and now I have 1-2 shift and have changed the solenoids and still nothing. Others I have talk to said it will not run on this computer. So what's next?
07-10-2015, 07:41 PM | #18 | |
If Bill @ BP Automotive sent you another PCM, & Built your Harness? We can just about rule out the PCM or Harness being the problem. He built my harness & tuned my PCM, And mine was way "off the wall" stuff compared to yours. Did you make sure the Tone Wheel is on the Output Carrier? Has anyone Logged data? Or at least hooked up a Scanner to see if 3rd gear is being commanded? Watched the VSS data? Are codes being set? |
07-10-2015, 07:11 PM | #19 |
meowMEOWmeowMEOW
FWIW, I'm running a 97 4l80e on mine behind the 6.0
The v8/auto ECM's from 2000-2006 shouldn't have a major fit about controlling it....unless the whole transfer case thing is part of the problem (no clue on 4x4 stuff). The ECM's don't care about the displacement, so long as it was a v8 auto...and even then there are things that can be done. I'm curious, they keep saying "you need a different computer"...so WHAT computer are they trying to tell you to get?
07-17-2015, 07:03 AM | #20 |
Yelp transmission guys in FL are ?????? know nothing and still insisting that I have to have a 6.0 and computer can not be flashed to run with 5.3. Trans pulled and at different shop were the clutches are coming apart and had bad manifold and broke wire to a solenoid. Thanks for the help guys and will be back on the road next week.
07-17-2015, 09:09 AM | #21 |
Like cline mentioned and it may have been said above there is what they call a "segment swap". To run a 4l80 transmission on a computer originally set up for a 4l60 this must be done. It is not as easy as just clicking the button inside HP tuners. It changes lots of internal stuff. That said it is not a hard thing to do but needs to be done. If that has not been confirmed with your tuner then I would start there. I have not done this but I do have an 80 in my show that I am going to swap sometime and will need to do that when I do the swap.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
07-17-2015, 10:49 AM | #22 |
meowMEOWmeowMEOW
You gotta click a few buttons
07-17-2015, 12:35 PM | #23 |
BP Automotive tune and wiring harness so it should go once transmission is built with new clutches and band. I think that's all I can do until trans comes back.
