05-31-2015, 01:44 PM | #1 |
63 C10 bolt pattern change
I'm sure there is already an answer for this. I'm considering having my 6. Lug rear axles drilled to 5 on 5. Is there a 5 lug drum that will fit.
Thanks as always
Scott 63 C10 Stepside 230 1bbl Saginaw 3 spd |
05-31-2015, 09:42 PM | #2 |
Re: 63 C10 bolt pattern change
71-87 HD brake drum
Not the light duty ones oh and you will need to have the center part of the axle turned some as well. Just take a drum with you to size them properly.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-01-2015, 12:23 AM | #3 |
60-66 Nut
I will have to disagree on that. The '71-'87 HD brakes will have 2-3/4" wide shoes. Those will not work on an earlier truck without changing the backing plates. And on a '63 12 bolt, you can not do that as the backing plates are pressed onto the axle tubes.
What the OP will want are the '71-'87 light duty brake drums for the 2" wide shoes. I do agree that the hub register on the axles will have to be turned down to aprox. 3.062" to fit the 5 lug drums.
05-31-2015, 11:32 PM | #4 |
Is there a Part# ?
06-01-2015, 12:27 AM | #5 |
60-66 Nut
Just pick a year between '71-'87 and go to your parts supplier and ask for rear drums. They will ask you what size shoes and just tell them 2" wide shoes.
06-01-2015, 01:01 AM | #6 |
Just curious, would HD drums & the corresponding backing plates & brake pieces fit a 64-66 rear. I plan on towing my boat & heavy loads(firewood, etc.), and HD brakes would be a bonus
Living The Canadian Dream in British Columbia |
06-01-2015, 08:15 AM | #7 | |
I do NOT suggest it but I know of several trucks, driven daily, which merely used NUTS over the longer bolts to extend the backing plates. Luck to you after making nice, proper spacers! Sam |
06-02-2015, 12:38 AM | #8 |
60-66 Nut
The HD brakes (2-3/4" wide shoes), backing plates will bolt right up to a '64-'82 truck 12 bolt. The backing plate flange bolt pattern is the same as well as the brake offset. In fact the brakes from a '80-'87 8.5" truck 10 bolt will bolt up as well.
I don't understand the spacer suggestion as that would move the backing plate the wrong direction.
06-04-2015, 05:34 AM | #9 |
Sorry, but the spacer idea was with using '71 axles and HD backing plates/shoes in '66 models--'63 may differ. *Without the spacer, the 2 3/4 drum would not 'reach and cover' the shoes.
Sam Last edited by luvbowties; 06-04-2015 at 05:45 AM. |
06-01-2015, 01:15 AM | #10 |
Thank you for the info!!!!!
06-01-2015, 07:52 AM | #11 |
Thanks Captn! I stand corrected ( backwards again!)
