Old 06-01-2015, 02:43 AM   #1
RedRoad
RedRoad's Avatar
BFG 35/12.5/16.5 available again!
I see an availability date of early July for another run of BFG AT KOs. Fairly cheap at under $240 a tire but realize this may be the last time they are available. Ive been considering getting some Vintiques 16x8 rims and going with a 315/75 but notice BFG is phasing out 16 inch tires now as well.
Wondering if other companies are also getting rid of 16 inch LTs as well. Anyone hear of the 16 going away?
Anyone know of a steel 17inch rim that will take a stock 3/4 ton hubcap? I refuse to put tacky modern alloy wheels on my classic, any help appreciated
RedRoad is offline   Reply With Quote
Old 06-01-2015, 08:06 PM   #2
Mike C
Mike C's Avatar
Re: BFG 35/12.5/16.5 available again!
Not sure what BFG's intentions are with other sizes. I bought 5 35 12.5 16.5 for my Jimmy just over a year ago thinking they might be gone for good. They had been reduced lots of places. I got them for $165 each at Summit.
This probably last time I do the 16.5 on my billet Centerlines, but I figure I've got 9 more years!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-02-2015, 01:32 AM   #3
ajviper
ajviper's Avatar
http://www.bfgoodrichtires.com/tire-...ails#techspecs
My friend runs a tire shop.
BFG is currently switching from the KO to the KO2 along with KM to the KM2. This is probably why you aren't seeing many 16s in a KO.
More sizes are still due out later this year to my understanding from the info he got from his distributors.
There are 9 16 inch tires listed so I don't think they are abandoning 16s. He has not heard anything about 16.5s. The last set he got in was last year.
Chevy Runs Deep.
1956 210 LS1 TH350 3.31 Posi 12 Bolt
1969 Z/28 5.3 T56 3.73 Posi 12 Bolt
1973 Nova SS 355 TH350 2.73 Posi 12 Bolt
2000 K2500 Suburban LS 6.0 4L80 3.73 G80
2005 K2500HD CCSB LS 6.0 4L80 4.10 G80
2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic
ajviper is offline   Reply With Quote
Old 06-02-2015, 02:28 AM   #4
swamp rat
swamp rat's Avatar
When i bought my new set of BFG 33" 16.5's at Discount tire they said that the demand was still there so they were gonna keep making them, this was about a year or so ago, this was about 3 months after Les Schwab told me they were going to be gone.
I hope they are still around cause i was thinking about buying a set of 35" down the road...
No idea what KO KO2 or KM KM2 mean ??
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-02-2015, 09:47 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Key benefit Off road
Key benefit Mud
2nd generation
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-02-2015, 07:48 AM   #6
Mike C
Mike C's Avatar
KO is the oler BFG All Terrain and KO2 the most recent. KM the older mud tire and KM2 the newer tread pattern and caracass.
Old 06-02-2015, 01:29 PM   #7
swamp rat
swamp rat's Avatar
Humm, no idea if i have the KO or the KO2 now.. Not that it matters, Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-04-2015, 01:56 AM   #8
60sIron
60sIron's Avatar
I've been looking and posting about 16.5 tires for two months. 33" no more. Folks posted you could still easily get 35" but nobody told me where. I've literally called over 20 tires dealers and BFG. No 16.5 tires in those 2 sizes. You can get 29" and some in 37". But for the majority of us, we're out of luck. I'm hoping I'll be safe with 16" steel wheels.......... But then if you told me they'd discontinue a 33x12.5x16.5 tire a year ago....... I'd of laughed.
60sIron is offline   Reply With Quote
Old 06-04-2015, 05:07 AM   #9
andrewmp6
I can find recapped 37s for the 16.5 https://www.treadwright.com/individu...-37-13R16.50-D
Old 06-04-2015, 09:13 AM   #10
Mike C
Mike C's Avatar
I originally had the 36 12.50 16.5 Wrangler RTII on the Jimmy. They were exactly the same size as the 35 12.50 15 BFG MT that were on the truck, but the 37" radial is a LOT bigger. On my truck was going to require either significant fender trimming or going to a 6" lift.
FYI, the bias tires sucked pretty much. They looked awesome but like bias tires do, they flat spotted, lane walked, and were loud. But all 5 delivered for $550 and a deal on some closeout rims made it worthwhile for the 8 years they were on the truck. YMMV.
Old 06-04-2015, 10:07 AM   #11
All I know is mine are OK, but I better hurry up and do my springs and run them while they're still OK.
I sold my 6" lift, 37/12.50-16.5 SSRs mounted on Kelsey-Hayes 16.5 x 8.25s last summer. I'm going with 4" and run this set I bought terribly cheap. 35/12.50-16.5 BFG A/Ts mounted on 9.75 aluminum slots. I may need zero rates. These were the mild set for the 6" lift originally. My plan is to keep tires on these wheels, but also want 16x8 steel wheels and maybe 35/10.50s or anything down to 255/85 or 285/75. I hope I can keep running 16.5s
Old 06-05-2015, 12:56 AM   #12
RedRoad
RedRoad's Avatar
Summit has the 35/16.5 shipping the beginning of July and Jegs will have them end of July.
4wheelpart had no clue
Old 06-05-2015, 01:34 AM   #13
60sIron
60sIron's Avatar
RedRoad I'll call again. But I'm not lying, I talked to Summit Tuesday. On the phone for 20 minutes with a super helpful phone rep. he tried to help me find a wheel I liked in an 8 lug. The one I wanted wasn't available so most of the time he was looking for a 33 or 35x16.5 tire. Nothing............. I'm not making this up. When I called BFG they said sorry not available. I've been told by other forum members that they (BFG) does a run of that size once or twice a year. I've never gottin that responds from any tire dealer I've contacted. I wish it weren't true as I can't believe they would discontinue such a popular size........
Old 06-05-2015, 02:12 AM   #14
RedRoad
RedRoad's Avatar
http://www.summitracing.com/parts/bfg-56149/overview/
Old 06-05-2015, 12:17 PM   #15
60sIron
60sIron's Avatar
RedRoad thanks for directing me to the sight. Once again I called Summit and talked to a rep. to find out what is going on with this tire size. He said they have 50 back ordered with no delivery date. He put me on hold so he could call BFG. When he came back he was also surprised at BFG's responds. He was told that they could only look at tire production runs 4 weeks out. That size 35x12.5x16.5 was not on the list. He said that wasn't the answer he expected and I may be right. So are they ever going to make them? No other tire manufacter makes that size, you'd think I'd be a cash cow...... When I called BFG a month or two ago, the person I talked with was so sure they discontued them she told me to call Coker tires........
My solution 16" steelie's with caps. Keep my 16.5 slots in case they start making that size again.......
Thanks again and please keep me posted if you get more information.
Greg
Old 06-05-2015, 01:24 PM   #16
RedRoad
RedRoad's Avatar
Typical big corporation, total lack of communication between production and sales. A few months back I checked the BFG site for any 16.5 tires and none came up. Two weeks ago I started looking for some 255/85/16 KM2s to find them no longer listed which I thought was strange as my brother got a new set a few months back. I did notice that while looking at tire size option the 16.5 was now offered and the 35/12.5 was again listed
http://www.bfgoodrichtires.com/tire-...o/tire-details
Hopefully they will come to be and like you said a TON of old rides out there want/need this size. I think a 33/12.5 would be pretty popular as well.
Old 06-11-2015, 01:42 AM   #17
60sIron
60sIron's Avatar
RedRoad looks like it's just me and you here........... I called WheelVintquies 82 powder coated in white 16x8 8 lug $169 each........ 10 to 12 weeks out! Very proud of there wheels....... This whole thing gets me more pissed! Local powder coater $75 per wheel 14 days at the most. Looks like I'll be searching CL and pick and pull. SOMEONE TELL ME WHY THEY WOULD DISCONTINUE SUCH A POPLAR SIZE! Are 16" next to go?
Old 06-11-2015, 01:43 PM   #18
RedRoad
RedRoad's Avatar
At least you got a response from WV, not even a courtesy email saying if they even had the rims in stock. I ended up getting mine from Summit for $117 each and got them in 2 days after ordering. I did email them to see if they were available bare or in white pc and they only had satin black pc in stock.
http://www.summitracing.com/parts/wvi-82-680804
Back when I was looking for 16.5x8.25 in the p&p it took me a few months to get a set together, Ive never even seen any modern 16x8 rims available so not sure what your luck may be. The ford 16x7 might work but most places will not mount a 12.5 tire on a rim less than 8 inches.
Im going right now to pick up some BFG 315/75/16 from 4wheelparts at $217 each so hopefully Ill be good for a few years.
Old 06-11-2015, 02:34 AM   #19
andrewmp6
I say the next 5 years tires for 15s and 16s will start to die off.Most new cars and trucks run a 17 to 20 inch rim factory now.
Old 06-11-2015, 08:01 AM   #20
Yeah, the industry had to go get all stupid and shoot themselves (and us real truck guys) in the foot by catering to silly fad sized wheels and tires. This fad began with low-brow scum gang bangers and now the general populous follows suit. All that has resulted is much higher tire prices and huge difficulty stocking a zillion different sizes. Why would they do this, and all for a fad? Pure stupidity! What next, change tires to some other shape than round? I guess tires rot and fall off the rim before their time now because the tire companies have cheapened the material to help compensate for the added cost of tooling, line changes, and logistical nightmares created by so many sizes
Old 06-11-2015, 12:35 PM   #21
61K10
61K10's Avatar
60sIron--I just bought 4 16x6 6 lug black power coated trailer wheels for $65 a piece from etrailer.com with free shipping. pretty sure they have 8 lug in 16" don't know how wide though.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-11-2015, 03:56 PM   #22
61K10
61K10's Avatar
the trailer has 16.5x9.75 in 2 offsets
1961 chevy K10
Old 06-12-2015, 12:07 PM   #23
RedRoad
RedRoad's Avatar
Here are the new WV 8x16 with BFG 315/75/16 tires. Mounted they measure at 34.5 inches tall and a full 12.5 wide.
It troubles me that these days I had to sell a car to be able to afford tires for my old truck. Luckily for me old VWs are up on value so I was able to get the tires and locker for the HO52 (Thanks Jeff!!)
Old 06-12-2015, 05:51 PM   #24
60sIron
60sIron's Avatar
Now that's some rubber! What are you putting them on RedRoad?
Old 06-12-2015, 07:49 PM   #25
RedRoad
RedRoad's Avatar
Got a package deal from my brother when I bought the suburban but have to get it out of storage and the dry rotted BFG MTs wont make the trip.
1973 GMC Jimmy 350/465/205 D60 posi/14B detroit 4.56 gears.
Im trying my hardest on saving the HO52 in the suburban but if all else fails the 1 tons will make it under there with the new shoes.
