Old 06-02-2015, 07:40 AM   #1
jnf2k2
Vintage Air kit..............worth it?
Just wanted to get a few opinions on here to see if people feel that the Vintage Air kit is worth the 1400 bucks you pay for it. I currently have no a/c in the truck (evaporator and condenser were removed when i got it) and the hot muggy Florida summers are upon us. So an a/c would be really nice to have?
Also how would i know if my truck orginally came with a/c? It has the vents and controls on the dash, but I wasnt sure if that a dead giveaway.
Oh and this is going into a 76 K10.
jnf2k2 is offline   Reply With Quote
Old 06-02-2015, 08:23 AM   #2
Lokin4AReason
Lokin4AReason's Avatar
Re: Vintage Air kit..............worth it?
any photo(s) .. ?
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 06-02-2015, 08:41 AM   #3
77c10
77c10's Avatar
I installed VA in my 77 C10 over the winter. It's not my daily driver and only gets driven to cruise in's/car shows. I can say without a doubt that it was worth it to me. 20 years ago i could stand not having AC. Never again...
Installation was very straightforward as long as you follow the directions. It took me WAY too long to install mine but I would say it could be done easily in 2-3 weekends or 2-3 days straight.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 06-02-2015, 12:35 PM   #4
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Why not just go to the junkyard and grab all the a/c stuff off a parts truck?
Easy way to tell if your truck came with a/c is by the fan box. If it hugs the firewall and just has heater lines going to it, it's a non-a/c cab. If it has the box for the evaporator, sticking out by the passenger manifold, then you have an a/c cab.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 06-02-2015, 03:16 PM   #5
Skunksmash
Skunksmash's Avatar
Finding all the leaks and doing all the repairs to that old stuff is quite a PITA. I can easily see why someone would want to just skip it and go with a brand new system that doesn't come with all kinds of problems.
Skunksmash is offline   Reply With Quote
Old 06-02-2015, 03:40 PM   #6
Rogier
Pros:
  • Fixes all the old crap in one replacement unit. No more vacuum misery, flaps getting stuck or cores that crack every other year
  • Works easy and efficient and looks good
  • Absolutely foolproof to install
Cons:
  • The heat is controlled via an electronic valve that cuts the hot water of from the heater core. This is a good idea is you don't need the hot water for other purposes as well. I do and had to find yet another hot water source on the engine to tap into.
  • It does not let outside air in, only inside circulation is possible
  • It's noisy compared to stock
  • NOT cheap
All in all, I'd still do it again.
Rogier is offline   Reply With Quote
Old 06-02-2015, 04:01 PM   #7
tucsonjwt
I don't have VA, just stock a/c, but I do like the idea of all electronic controls on the new version of the VA kit. The vacuum controls on the stock system (and all vacuum controls, as far as I am concerned) are always of questionable operation with the stock system. In this modern era, I see no need for vacuum controls - just electronic. From what I read, for maximum cooling, the old R12 systems are the best, but the compressors do leak. My old R12 1976 C20 was the coolest A/C I have had yet.
tucsonjwt is offline   Reply With Quote
Old 06-02-2015, 04:13 PM   #8
Ozzy2013
Ozzy2013's Avatar
Im on the fence for many of theses same reasons with i could find one for 1,000 ha ha
Ozzy2013 is offline   Reply With Quote
Old 06-02-2015, 02:45 PM   #9
rich weyand
rich weyand's Avatar
One reason to go with the VA kit over a stock system is that the entire VA kit is contained in an airbox behind the firewall, so there is no big box for the evaporator under the hood. Cleaner underhood look.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 06-06-2015, 03:57 PM   #10
whitels1
whitels1's Avatar
I just did this on my 84 K10 w/out A/C and did video the whole way. It was super easy to install myself, the only thing I had to have someone else do was crimp my hoses and evac/recharge it. My kit was a little bit more because I had to also get a high mount for the compressor since I have an LS in the truck. It worked great the other day when it was 95 outside, I'll really put it to the test when it's 120 and I'm idling through the desert
Here is my build thread, starts about post #84
http://67-72chevytrucks.com/vboard/s...11#post7194311
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 06-07-2015, 10:09 AM   #11
Greenlee
Greenlee's Avatar
I have been running Vintage Air in my truck for about 2 years now. It has been flawless. Ice cold in the summer and heater works good in the winter.
Greenlee is offline   Reply With Quote
Old 06-07-2015, 12:17 PM   #12
Skunksmash
Skunksmash's Avatar
Originally Posted by jlelec View Post
I have 4 Square bodies and all have factory air. I have had limited success getting any of them to cool good when its 95 deg and 90 percent humidity in GA. I think a lot of the problem is the R134, it just does the best it can. I have tried all the tricks. I had a 69 camaro with Vintage air and it was great! I just started on an factory air 77 resto and will strongly consider Vintage air and ditch the factory air.
My truck has factory air, and I haven't had much problem with its cooling. When the thing works. Every winter when I stop using it for 5 months, it leaks out all its coolant and I have to have it fixed. I live in TX, really hot here and we also have some 90% humidity days, although probably not as many as you do in GA.
After all my experience with them over the years, I'd say these factory AC systems are problematic. You need a good AC tech to keep them going for more than one summer at a time. Mine keeps finding a new way to leak every year.
Old 06-06-2015, 10:01 PM   #13
andrewmp6
1400 for a brand new ac system sounds like a lot but its not.I have seen people spend more to repair a ac system on a newer car/van before.
Old 07-08-2016, 12:34 AM   #14
mosel70
Yes, worth it. I just finished my own install of a Vintage Air (VA) A/C system in my '70 C10 which did not have factory air. It's summer and I live in Las Vegas. I had a local A/C shop do the evacuation and charging, and no leaks. It blows really cold and large volume air, fan speed is variable. Great decision. Getting the ducting in under the dash was a bit sporty but doable. They provide very soft flexible ducts which really helped. Well worth the money. It requires five different metal drill sizes and removal of the right front fender which I replaced with a new one since it was only $80. The VA instructions are very good.
While I was at it, I installed an aluminum radiator and new pulleys.
The whole job took me about 4 full days over three weeks.
mosel70 is offline   Reply With Quote
Old 07-08-2016, 07:19 AM   #15
D13
D13's Avatar
My 87 uses the factory system converted to R134. Will literally freeze you out of the truck. You need the long compressor on the conversions, the radial compressors are too small. Sandeen versions seem to be small but they are more efficient so they probably do OK.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 07-08-2016, 08:14 AM   #16
Red Beard
Red Beard's Avatar
My 87 has factory a/c, but I was looking into the Vintage Air stuff, just so that everything was new. I guess their kit doesn't work with an 87 though, for some reason. Just the 73-86. So, that pretty much made up my mind for me.
1987 R10 Silverado "Farm Fresh" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=703698
Red Beard is offline   Reply With Quote
Old 07-08-2016, 09:01 PM   #17
calvin78612
calvin78612's Avatar
I just installed a VA system in my 87. Super easy and man that thing will freeze you out of the cab. I also bought the Alan Grove brackets to swap my alt. to the l/h side and a/c comp. to the r/h side. It is a great system, the Sanden comp. has less patristic drag and is very efficient. You will not be disappointed with the VA setup !
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 07-08-2016, 11:12 PM   #18
Red Beard
Red Beard's Avatar
So they do work in the 87s?
Old 07-09-2016, 09:21 PM   #19
Greenlee
Greenlee's Avatar
I asked Vintage Air why they don't advertise that the kit will fit an 87'. The guy I talked to said that the under dash unit may interfere with the mounting location of the stock computer. My cab is an 83', but I'm running TBI from an 89' Suburban. I was able to fit the computer on top of the Vinage Air unit.
Old 07-09-2016, 10:39 PM   #20
calvin78612
It is a tight fit but I unplugged my harness plugs on the ecm, then I installed the front two mounting screws on the a/c unit then plugged it back in.
84 step side
87 swb
Old 07-09-2016, 02:18 AM   #21
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
I installed a VA A/C kit in my 72 Burb. Gets so cold I could hang meat!
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 07-09-2016, 07:44 AM   #22
calvin78612
Yes they have a system for the 87's. Call them and they will set you up. Order through Sumit Racing ( free shipping ) It really cleans up the firewall and looks great. I am about to wash my truck and I'll snapped some pics of the firewall.
84 step side
87 swb
Old 07-09-2016, 12:45 PM   #23
calvin78612
Engine bay
84 step side
87 swb
Old 07-09-2016, 01:35 PM   #24
Desert1957
Desert1957's Avatar
Engine bay
Is this the kit shown in your pic? I am also curious about the posting that commented about the system being "Noisy".
I have thought about this upgrade on my 87.
Name:  0612clt_01_o+vintage_pickup_truck_air_conditioning_system_installation+vintage_truck_upgrades.jpg
Desert
Desert1957 is offline   Reply With Quote
Old 07-09-2016, 08:28 PM   #25
calvin78612
That kit looks a little different than mine, give me a second and i'll run out to the shop and find the correct # for my kit. As far as being noisy if its on full fan it can be a bit noisy but that's what the radio is for, plus when it's 100 degrees outside I really am only concerned with staying cool. Again worth every penny !
84 step side
87 swb
