06-04-2015, 09:10 PM | #1 |
06 2500 HD 4x4 wheels/tires
I recently picked up an 06 2500HD 4x4, and I'm looking at the truck, and I can't help but think the tires look puny as hell. I don't want to lift the truck yet, just put some nicer wheels and tires on. Something like American racing AR's( http://www.americanracing.com/wheels...1721/techsheet ) and BFG all terrains.
here's the truck I was hoping someone could make a size recommendation to me. I don't want the wheels to be any bigger than 17", and I would prefer they don't stick out drastically passed the fenders and flares. Thanks- Eric
'06 2500 HD 4x4. manual transfer case, crank windows. '88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project. My trucks don't leak oil, they mark their territory. |
06-07-2015, 06:57 PM | #2 |
Re: 06 2500 HD 4x4 wheels/tires
What size tire I'd on it now?
1949 Chevy C3100 1979 GMC K25 1982 Chevy C20 2000 Chevy K2500 2002 Pontiac Trans Am |
06-07-2015, 07:00 PM | #3 |
06-07-2015, 07:15 PM | #4 |
If it were me I would put 235/85/16 they are around a 1.5" taller and around the same width. Or if you want a little bit taller and wider tire 265/75/16 they are about an 1.5" taller also but about 1" wider also. The 235's will be a little cheaper. but both will fit with no lift
06-07-2015, 07:34 PM | #5 |
All 3 tire have the same load rating E (a little over 3000 lbs.) and the all are 10 ply tires
06-08-2015, 12:26 PM | #6 |
I personally like the 265/75r16 or 265/70r17. I run the 265/75r16 on the factory rim and I like the look. I wish it was on a wider rim so the tire looked a little beefier, so I think the 8" you have chose would be a good choice and who doesn't like 17" wheels on these larger modern vehicles! The 265 looks like what the factory should have installed and in 08 the 265/70r17 was an option. A 285 would fit, but then your tire size will throw off the speedo even more without addressing it in the ECM. The 265 options listed above are the same diameter and width as each other just 2 different rim sizes and they will trow your speedo off by about 4%,not enough to worry about, so when you are going down the road at 65 you are really going 67.5ish.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
06-24-2015, 06:19 PM | #7 |
285/70/17 tires. i have a 04 crew cab 4x4 and used the H2 Hummer wheels and kept my centers, they fit perfect and look factory.
06-26-2015, 07:11 PM | #8 |
Follow up:
285/75R16 BFG All Terrain Ko2 on 16x10 Mickey Thompson Classic III's The scrub a little bit, so I have a little angle grinder+hammer magic to work and then they'll be good.
06-27-2015, 11:57 PM | #9 |
I like that look! I have the same truck in white, so I want to go with black wheels and a little beefier tire. Love the truck
06-28-2015, 06:52 PM | #10 |
Thanks, I really like the look too, but I might need to lift it a little in the front, it scrubs pretty bad...
07-21-2015, 12:19 AM | #11 |
Did your truck have the painted rear bumper? Mine did, it rusted all through so I linexed it. I see you did something to yours, just wondering what? It looks great!
07-21-2015, 12:22 AM | #12 | |
Right now, the plan is to fab a new front and rear bumper, along with a leveling kit to hopefully eliminate the rubbing. Thanks for the compliment.
