06-06-2015, 04:39 PM | #1 |
Help with belt routing
Guys, I need some guidance on routing my belts. I've added power steering and I have a Vintage Air system as seen below. I have 2 grove pulleys on the water pump, a/c compressor and the p/s pump. Single grove alternator.Have a 3 grove on the crank pulley. How best to rout the belts?
Figure out what you want--then figure out what you are willing to give up to get it. |
06-06-2015, 07:42 PM | #2 |
Re: Help with belt routing
Can I run one belt around crank, p/s pulley (1st groove) and alternator pulley?
Then a second belt around crank and P/S pulley (2nd groove)? Also a 3rd belt around water pump pulley and a/c pulley. Would this set up work?
06-06-2015, 10:38 PM | #3 |
Depends on what lines up with which part of the crank pulley and the water pump
06-07-2015, 03:50 AM | #4 |
Stock 350 sbc has the alt belt to the back on the crank and w/p pulley.
P.S is on the front crank pulley groove.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
