Old 06-07-2015, 06:35 PM   #1
Malo83
Cruzzzn' Vet
Malo83's Avatar
2000 Blazer, no brake lights
Wifes S10 Blazer has no brake lights except for the third brake light on the roof, switched out the brake switch on the pedal, checked all fuses and replaced the four tail light bulbs, tail lights work normally just not when braking???
Malo83 is offline   Reply With Quote
Old 06-07-2015, 07:13 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: 2000 Blazer, no brake lights
Check the hazard switch/multifunction switch on the steering column. Sometimes the contacts get a little loose in the hazard switch.
Do the hazards/turn signals work?
We also have an s10/blazer section.
95 S_Trucker is offline   Reply With Quote
Old 06-08-2015, 05:01 PM   #3
Malo83
Cruzzzn' Vet
Malo83's Avatar
Thanks Trucker, anyway I can get this post moved over to the S10/Blazer section
Old 06-14-2015, 08:30 PM   #4
hugger6933
I was gonna ask if the HMSL [that is high mounted stop lamp for those that don't speak the Newer GM] lights upon mashing the pedal. That indicates the multi function turn signal switch. The 3rd light is not hooked into the multi switch and if you have problem related to the lights [excluding headlamps] the multi function switch is most likely the culprit.I don't know why they had to do that but they did and the switch is high as a giraffes back
hugger6933 is offline   Reply With Quote
Old 06-29-2015, 01:01 PM   #5
Malo83
Cruzzzn' Vet
Malo83's Avatar
Thanks Trucker, the hazard switch was the problem, cycled the switch a few times and the brake lights are back, never would have figured that one out
Old 06-30-2015, 07:27 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
cool. Now you can look forward to your flasher (in glove box) clicking on it's own without the lights illuminating
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-30-2015, 03:10 PM   #7
Malo83
Cruzzzn' Vet
Malo83's Avatar
Great!!!
