Butchered radio opening! What'd you guys do?
So my truck's PO tried to cut the radio opening and did a terrible job of it.
I don't have near the skills to weld in a new section, and I'd hate to lose pin stripping on other parts of the dash, so I was wondering what other folks here did with there cut up messes. Thanks in advance! |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Butchered radio opening! What'd you guys do?
You could JB WELD a replacement piece from behind after carefully cutting out the butchered section along the curved section.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
This is an easy fix...but first, are you wanting to install another radio? If so, are you going to go with another radio that utilizes the control knob shafts to mount the unit or will you be going with a single-din unit?
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
#4 | |
See THIS LINK POST #247. That's my truck. I used a patch cut from another 64-66 dash but vendors also sell the patch piece. You CAN do this!
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#5 | |
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
I'm in the same position lug. Broke as a joke. Trying to make do. I like the Velcro plate temporary solution. May give that a shot
Hey Paul... Pm me about what that might cost if you don't mind. Thanks |
Check out post 61 of my build thread HERE
All it cost me was a 5 dollar piece of aluminum. Once I painted it the color of the dash, it was almost invisible...
LDO that looks awesome man. As does the rest of the truck.
![]() Join Date: Sep 2006
I swear it looks like he used a hammer and a chisel. Maybe an air chisel. The PO needs to be slapped.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 06-08-2015 at 03:35 PM. |
#10 | |
Holy cow lug! You did an awesome job.
Wolfman, I thought My truck had it bad.... Yikes sorry man. You def made the best of it. I don't plan on putting a radio back in for a while, but when I do I'd like it to be stock. Eventually I'll have to work up the nerve to do what Lug did, but for now I'm just trying to hide the hole. |
#12 | |
On my fleetside, the PO drilled like 30 holes all over the dash, cut the speaker vent, dented the ashtray hole and of course the usual hack job on the radio hole.
I opted to just replace the entire dash with a nice unmolested donor to fix all the issues at one time. They do make dash repair panels also that will fix your issue.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
![]() Join Date: Sep 2011
I am parting several 60-66 trucks and could cut a repair panel out.
#15 | |
#16 | |
Posted via Mobile Device |
#17 | |
#18 |
I used a radio repair panel I found on line. Cut out the piece I needed , welded it , and now working body work to finalize and paint. |
#19 |
All guys braving the proper fix has got me thinking maybe I should try it.
#20 |
![]() ![]() Join Date: Aug 2013
Take your time and repair it right, its something you will look at every time you drive the truck. I went with a radio delete plate look after the repair, good luck with your project.
#21 |
So we almost have you convinced of welding in a patch. I did mine it was just like yours except mine only had one ear left. I bent the ear back in place. Straightened up and welded it. Then I cut a patch to fit the hole. At least I have the one hole to help make the other two holes for the original radio. Haven't bought one yet and haven't cut out the holes yet. I have very little welding experience except for restoring this truck. You can do it.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
#22 |
radio holes I see are still there on your truck. How bout covering it up. I did this http://67-72chevytrucks.com/vboard/s...d.php?t=614582
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
#23 |
Conrad,
I will gladly send you a donor section of dash for you to fix yours. It's not perfect but it should work nicely in your truck. Just cover shipping and it's yours. I have 2 and only need one. Then you can post your repair here in your thread.
#24 |
Bj- that's looks great, good job man.
Doobie- I bought that same delete off feeBay, and it didn't cover the damage by a long shot. Yours looks cool though, dig that silver. LDO- that would be awesome man, I'd really appreciate it. Just tell me what you need for shipping and I'll get it to you. I'm equal parts nervous and excited to try this out.... |
#25 |
I went with gauges - need a second push button for the other hole still, but you get the idea..
Barney, in the UK 1962 Chevy C20 1974 Ford Econoline 1987 Peugeot 205 GTi 1991 Peugeot 205 GTi |
