Ephesians 2:8
72 402 and AC items
ALL SOLD Thanks for looking!
I just finished an LS swap on my 72 Suburban. I ended up with a few extra parts that I had intended to store for a rainy day. Well I'm already tired of tripping over it all. So listing it here to see if anyone wants any of it. I have 2 402 bare blocks. One needs bored, other needs a sleeve in cyl 7. This is the block that needs a sleeve the other has the same suffix code ![]() They both have the same casting numbers, ![]() Here is the reason the first block needs a sleeve. Casting flaw... ![]() To go with these blocks, I have the following 2 cast cranks, one needs turned other needs polish 16 Pistons and Rods, 15 rod caps....(one was missing off of second engine) 2 pair of heads, I'll provide the casting numbers later, stock round port. 1 pair of Valve Covers 1 Pan 1 stock intake 1 Rochester 4BBL 1 Starter ( newer reman ) 1 Alternator 1 AC Compressor I also installed vintage air, and have the underhood and underdash AC/Heater items. I retained the indash control, but all cables are there and covers are in great shape. Lines from compressor to the condensor, to the evap. I will provide pictures of that as well. I would like to sell the engine items as a whole, package deal $600, as far as the AC goes, I would like $200 for the AC items as a package deal. I live in Central Illinois, prefer local pick up, but I am willing to meet you with in reason, I'll travel your direction if it helps. Thank you, Brad
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build Last edited by bowtieguy79; 05-13-2016 at 03:46 PM. |
Re: 72 402 and AC items
I'd be interested in the carb if you would sell seperate.
Ephesians 2:8
You know, If you folks see something you want separate, feel free to make me an offer.
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
Brad can you tell me what numbers are stamped on the carb and how the throttle shafts feel?
#5 | |
Ephesians 2:8
I have this pic of it on the engine. It seems to possibly be a Olds/Pontiac carb. Reason I say that is the front style gas line hook up, most trucks I've messed with are side gas line ( at least the 78-79's I've messed with ) ![]()
Thanks. Nice burb you have there!
#7 | |
Ephesians 2:8
![]() ![]() I took a video of me wiggling the throttle shaft, it's uploading.
Bowtieguy79, by chance are you going to the Goodguys show in Columbus, OH next month? I would be interested in your engine package deal, but I live in Northeast TN.
Ephesians 2:8
I just looked it up, my boy has a baseball tournament that weekend. If it is something you are serious about, I could meet you. PM me we can talk more about it.
PM sent.
Interested in the underhood AC items, please send photos
Ephesians 2:8
Here are the photos of the underhood AC. I have the heater core as well, just failed to get a photo.
![]() Join Date: Oct 2008
Ephesians 2:8
It was intact before I removed it. I vac'd down the system and it would not hold vacuum. It is missing the indash control only. The rest is there. Less the T's that go to the rear ac, as stated before.
#15 | |
Does this include all the brackets to attach to the engine? Or is it just the plumbing itself but not the hardware ![]() Sorry for all the questions, just trying to clarify Thanks again Mark |
#16 |
In line after kingstrider for all the under hood AC stuff
#17 |
Ephesians 2:8
noted
#18 |
Brad thanks for the carb pics. Looks like it is original to a 76-77
454 gm truck. I'm wanting 72 specific. I would try the square body parts forum I bet somebody there could use it. Thanks. |
#19 |
Ephesians 2:8
thanks for the info!
#20 |
OK. Standing by
Thank you |
#21 |
Did you use the 72 engine frame stands for your swap? If not, for sale?
#22 |
Ephesians 2:8
I did not use the BBC stands, make me an offer, no rubber mounts included.
#23 |
You have only the frame towers? And there for 72, any pic's?
Gary |
#24 |
Ephesians 2:8
Yes 72 big block mounts. Stands and mounts, ready for replacement rubber isolators. I'll get you a pic some time over weekend
#25 |
![]() Join Date: Dec 2013
How much for the carb and big block towers sent to 37820 ?
