06-12-2015, 12:01 PM | #1 |
Plastic Tank? In or under is OK!
Ladies and gents. Going diesel and my metal tank is rusty inside.
Is there a plastic inside tank option? Is there a preferred plastic Suburban or other style tank for underneath? |
06-12-2015, 12:36 PM | #2 |
Moderator
Re: Plastic Tank? In or under is OK!
You couldn't use a new steel fuel tank with diesel?
$169 http://www.ebay.com/itm/Goodmark-414...e4f03e&vxp=mtr
06-12-2015, 12:37 PM | #3 |
Could but want to avoid corrosion at the top of the tank where there is air...injection pumps and injectors break the bank if the smallest bit of that gets in. Plastic or aluminum are really the only way to fly. Plastic will probably be a fraction of the cost though.
06-12-2015, 12:41 PM | #4 |
Moderator
Cat 1 Micron filter.
I use one on my engine and a Donaldson 3 micron at the fuel tank in my LMM. Of course my fuel tank is Poly as well, so your headed in the right direction.
06-12-2015, 12:43 PM | #5 |
I like that. So you still have metal in cab and hung a filter underneath and one on the stock cummins mount?
06-12-2015, 12:51 PM | #6 | |
Moderator
I conducted a search but havnt yet found a poly tank for the C10. I have a aluminum tank I have yet to use . . .
06-12-2015, 12:51 PM | #7 |
I think he's saying he uses a filter, but his tank is plastic as well.
06-12-2015, 12:53 PM | #8 |
Oh yeah I have a filter on the cummins but a metal tank is still going to corrode and impede flow more than a plastic.
Anyway - back on topic. Plastic tanks. |
06-12-2015, 01:22 PM | #9 |
Try going to Tanks Inc and searching "poly", they have a variety, one might work.
I noticed this one in particular. it is 34.5" x 19" x 8.5" and comes in left & right fill. (note I have no experience with this tank/site, just trying to help)
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures) SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD |
11-13-2015, 10:43 PM | #10 | |
11-14-2015, 11:08 AM | #11 | |
Never Ending Projects
Behind the rear axle is the only location this is going to fit unless you mount it inside the bed itself.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
06-12-2015, 03:57 PM | #12 |
I used a similar tank to that from Tanks Inc. in my '68 long bed. I moved the rear crossmember back and removed the spare tire brackets. Fit good. Haven't used it yet but I know it won't rust.
06-12-2015, 04:04 PM | #13 |
Senior Enthusiast
For what it’s worth – I had a poly tank under my 46 Ford sedan back in the late 80’s. I no longer remember who made it, but it worked great and was inexpensive. It also sagged badly during the heat of summer so I ended up putting multiple van straps under it to give it a better safety margin.
When considering the installation just plan for additional support underneath as these don’t have the rigidity of a metal component.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
