06-12-2015, 08:35 PM | #1 |
Air lock
I have a 327 in my 67, I believe it has a air bubble in the cooling system. How do I go about bleeding the air out? Thanks
06-12-2015, 10:45 PM | #2 |
Re: Air lock
I always drill a small hole in my thermostat.
06-12-2015, 11:26 PM | #3 |
Re: Air lock
Drive it. 50 million SBCs were made from '55 to 2000 and nobody drilled a thing. Well...
06-13-2015, 09:10 AM | #4 |
Re: Air lock
06-13-2015, 09:18 AM | #5 |
Re: Air lock
myth
06-13-2015, 09:25 AM | #6 |
Re: Air lock
I changed the intake, put a new thermostat , started the truck and added water/ antifreeze. It only took about 3/4 gallon. when the motor is running it starts to puke out the overflow and the top radiator feels as if there isn't enough water in it, but the radiator is full,
06-13-2015, 09:26 AM | #7 |
Re: Air lock
I meant to say top radiator hose. Duh!!
06-13-2015, 10:02 AM | #8 | |
Re: Air lock
Are you filling the rad right to the top or leaving the level down a couple inches? If you have a puke hose then leave the level down a couple inches. If you have a return/catch can then fill it full. The liquid expands when heated. |
06-13-2015, 03:24 PM | #9 | |||
"I ain't nobody, dork."
Re: Air lock
Gary
06-13-2015, 11:58 AM | #10 |
Re: Air lock
I'd have to say I agree. Because of the pump the coolant in the engine is under higher pressure than the radiator. The engine is filled from the bottom up. The radiator is filled from the top down. The air would tend to accumulate in the low pressure of the radiator, not the high pressure of the engine.
Regards, Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
06-13-2015, 02:41 PM | #11 |
Re: Air lock
Another way to burp it is to put the front end up. Either jack it up or park it on an incline it helps all the air work to the highest point.
06-14-2015, 09:37 PM | #12 |
Re: Air lock
Are you filling the rad right full when cold or are you leaving the level down a couple iinches?
Do you have the right rad cap? |
