06-14-2015, 06:47 PM | #1 |
Taking a step back to a 3ott and original motor....help wanted
Here again looking for some experienced help,
After looking at many trucks I find that most people are hotrodding them, which is great (383, 396, air bags...eat) But I have always wanted something different, a conversation starter. I am starting to think less is more for me, and I am not looking for something to race. I am going to take out that worm out 305 and put in a 283 I now have and a 3ott. Where the question comes is I have never worked on a 3ott so I am naive to what components I will need. I have a compelete 283 from a 1964 Chev, a 3 speed transmission, clutch pedal assembly, clutch and shift linkage, 3 speed Colomn. Still need to find are a bell housing, bell housing cross member, tranny crossmember, and clutch. You guys see anything I'm missing, I am hoping to do this over a weekend and want to try and avoid any major speed bumps. Correct me if I am wrong I will need to use the original forward mounting frame holes for the engine mounts? Mike
1967 SWB Small window Chev.....aka "The Skanky **tch" |
06-14-2015, 07:03 PM | #2 |
Re: Taking a step back to a 3ott and original motor....help wanted
I cannot give you technical advice but I am glad I am not the only one that loves the stock things. My truck is a 250 3OTT and I have no plans (ever) of changing it.
06-14-2015, 08:19 PM | #3 |
I have to agree. I have the original 6 with 3OTT. In the sea of big blocks, small blocks, LS conversions. Mine stands out as different. I hate following the crowd with the latest trends.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
06-14-2015, 09:24 PM | #4 |
06-14-2015, 08:34 PM | #5 |
This is a thread I started over the weekend. Everyone constantly ask me, Why not put an automatic in it. After they drive it they know. The 3OTT is becoming a rare bird and mine with the Borg warner overdrive is even more rare. My 67 is identical to what my father taught me to drive on and it will always be a 3OTT. If you need any linkages let me know. I have some spares left off from my correction conversion. But if you want your truck to be V8 correct this is everything thats needed in my post. Hope it helps.
http://67-72chevytrucks.com/vboard/s...d.php?t=673675
1967 c10 3OTT with R10 overdrive. 385 Stroker, 373 posi FITECH EFI, Vintage air, York 210 OBA, 4/6 drop with riddler 20x8 and 20x10 1957 S5T Leslie Supertyfon train horns and EMD bell "No bolt left unturned" |
06-14-2015, 09:05 PM | #6 |
I don't believe you need a trans crossmember. The bellhousing crossmember is all that is needed.
I don't mind my 3ott, but I would like it better if there were parts available to either replace or rebuild my column. It is incredibly sloppy even with new bushings in the linkage and proper adjustment. I can move the shift lever 2 inches without the the linkage ever moving. It would also be nice to have overdrive. |
06-14-2015, 09:27 PM | #7 |
Only the bell housing cross member is needed for a three speed saginaw. Keep in mind there are two models though. The inline 6 and the v8. And it all depends where your engine sits. The v8 sit 2" further forward and requires different engine stands. Again all this information is in my write up
06-14-2015, 09:30 PM | #8 |
Yea, i don't know how I missed that. Stupid mistake. You post is very imformative! I shouldn't need any linkage, a local dealer near me had all of that stuff, it's not cheap but by time I pay shipping to Canada with our dollar currently it probably would end up being similar in cost
