06-15-2015, 07:10 PM | #1 |
Tre 5 Customs 1980 C10 build
Here's another customer build I am working on. Everything on this truck is supposed to be top of the line per customer requests. I didn't go crazy over board with that idea, but I did do a lot of nice parts on it. Hoping to get this one to SEMA this year!
Here's a photo from the day he bought it. Here it is outside my shop a few weeks ago. And here's what we are going for
Follow me on facebook and Instagram. Tre 5 Customs My '49 http://67-72chevytrucks.com/vboard/s...d.php?t=673809 Customer build: 67 Blazer Roadster http://67-72chevytrucks.com/vboard/s...d.php?t=443105 Customer build 1980 C10 http://67-72chevytrucks.com/vboard/s...49#post7210949 |
06-15-2015, 07:15 PM | #2 |
Re: Tre 5 Customs 1980 C10 build
Ordered in a few parts:
22"x8.5" front and 22"x12" rear Intro Gallop wheels Some custom powder coated Baer brake. These are 14" drilled and slotted rotors and 6 piston calipers front and rear. A full Porterbuilt suspension setup including, front version 6 dropmember, frame stiffener, 24x15 rear trailing arm setup, watts link, and bolt on body drop. A few other came in later and I'll highlight those as the photos come in.
06-16-2015, 09:12 AM | #3 |
What size tires?
06-17-2015, 11:55 PM | #4 |
I'll have to look to make sure, but if I remember correctly... fronts are 265/30R22 and rears are 335/30R22
10-13-2015, 01:31 PM | #5 |
what brand tires are those if you don't mind me asking, I cant find anything size 335/30/22
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop |
06-15-2015, 07:17 PM | #6 |
06-15-2015, 07:17 PM | #7 |
I would be happy with how he got when he bought it.
Cant wait to see how this turns out.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-15-2015, 07:19 PM | #8 |
06-15-2015, 07:21 PM | #9 |
Then moved along to the rear of the truck and the 24x15 kit, starting with the notch and bridge assemblies
Followed by the frame stiffener, which also mounts the trailing arms and the carrier bearing for the two piece drive shaft. Here's the frame with everything but the watts link installed
Follow me on facebook and Instagram. Tre 5 Customs My '49 http://67-72chevytrucks.com/vboard/s...d.php?t=673809 Customer build: 67 Blazer Roadster http://67-72chevytrucks.com/vboard/s...d.php?t=443105 Customer build 1980 C10 http://67-72chevytrucks.com/vboard/s...49#post7210949 Last edited by tre5; 06-15-2015 at 07:32 PM. |
06-15-2015, 07:28 PM | #10 |
06-15-2015, 07:29 PM | #11 |
Then sat the brand new LS3 engine with a 4L65E trans from Turnkey Engine Supply in place.
The pulley setup is from All American Billet. The engine covers needed a tad bit of trimming over the AC compressor.
Follow me on facebook and Instagram. Tre 5 Customs My '49 http://67-72chevytrucks.com/vboard/s...d.php?t=673809 Customer build: 67 Blazer Roadster http://67-72chevytrucks.com/vboard/s...d.php?t=443105 Customer build 1980 C10 http://67-72chevytrucks.com/vboard/s...49#post7210949 Last edited by tre5; 06-15-2015 at 07:36 PM. |
06-15-2015, 07:31 PM | #12 |
I went with a set of ceramic coated headers from Sanderson that are meant for a s10 conversion. The fit perfectly other than one small area on the Porterbuilt stuff that needed a small notch.
With the cab back on (after cleaning up the firewall of all unnecessary holes and welding in a Porterbuilt firewall filler panel) we made sure everything fit nicely. Shocks come kind of close to the firewall and the driver's side engine cover needs a small amount of trimming.
Follow me on facebook and Instagram. Tre 5 Customs My '49 http://67-72chevytrucks.com/vboard/s...d.php?t=673809 Customer build: 67 Blazer Roadster http://67-72chevytrucks.com/vboard/s...d.php?t=443105 Customer build 1980 C10 http://67-72chevytrucks.com/vboard/s...49#post7210949 Last edited by tre5; 06-15-2015 at 07:39 PM. |
06-15-2015, 07:35 PM | #13 |
Then it was on to the exhaust. We opted for 3" from the collector back. All mandrel bends that have been cut and tig welded together. We have it running through 3" Black Widow Pro-series polished stainless mufflers. It goes to the outside of the frame rails so we can eventually exit it out at the rear bumper. We need to get the bed and bumper back on for this first though.
06-15-2015, 07:40 PM | #14 |
And here's where we are today. I threw a fender on, just to see it tucking some wheel. I'll update the thread as we make more progress.
06-15-2015, 07:57 PM | #15 |
67-72 parts collector,…
Subscribing for this epic build,...
06-15-2015, 09:45 PM | #16 |
Holy cow this is sweet!
Sub'd!
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
06-16-2015, 09:26 AM | #17 |
Frequent Flyer
Very cool build!
06-16-2015, 11:32 AM | #18 |
Wicked...looked great as it sat, now its just a beast
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
06-18-2015, 03:06 PM | #19 |
I just checked out your website. I didn't see anything for the 73-87 C10's. Do you have something for them? Looks like a nice product!
06-20-2015, 07:32 PM | #20 |
Sweet following!
06-18-2015, 02:03 PM | #21 |
Been seeing this on IG, gonna be awesome!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
06-20-2015, 07:56 PM | #22 |
Is porterbuilt going to be offering the parts you picked up for this? I know on their site they only have the frame brace listed for 67-72 c10s. I want one for 73-87 c10s
Matt |
06-29-2015, 10:59 PM | #23 |
Eventually they will be. I got kit number 1! Nate and I have a great relationship and he let me get a hold of the kit before it was actually released. There were a few bugs to work out because these squarebody frames have a lot of differences between the years and where they were sold. Once he works on my feedback from me and when he gets done with the one at his shop I'm sure he'll release it to the public.
06-21-2015, 09:09 AM | #24 |
Gracious!!
06-27-2015, 09:54 PM | #25 |
Nice!
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
