Old 06-17-2015, 01:06 PM   #1
y5mgisi
Second Chance Program
y5mgisi's Avatar
90 suburban rear doors on a 77 crew cab?
Will it work? By the looks of things the doors are physically the same. It's just the guts that are different. Is that correct? So I can gut my 77 doors and put the innards in the 90 doors and be good to go?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 06-17-2015, 04:06 PM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 90 suburban rear doors on a 77 crew cab?
I believe so. You will probably have to drill some holes to mount your door panels on the doors. I've asked others and this is pretty much what we came up with. I have a lot of 81 up rear doors and i thought about using them, but then I got a pair of near perfect rust free 76 doors.
Ryan
1969 Chevy milk truck
Old 06-17-2015, 04:10 PM   #3
1774btcrew
1774btcrew's Avatar
They are a direct bolt on with no issues. There won't be any extra holes to drill putting them on a 77
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 06-17-2015, 06:52 PM   #4
y5mgisi
y5mgisi's Avatar
Thanks! What about the window regulators? Lmc lists them as 81+. The 90 doors have power windows and I want to stick with the manual ones in the 77. Will the 77 regulators bolt up to the 90 doors?
Old 06-18-2015, 10:03 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
89 bolted up to my 78 no probs,but somebody did point out the roller wheel size changes at some point
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-19-2015, 12:01 AM   #6
esbstuff
77-91 should be the same shell...
Might be a regulator change (minor) in those years but nothing that would keep you from using the doors...
esbstuff is offline   Reply With Quote
Old 06-19-2015, 12:25 AM   #7
y5mgisi
y5mgisi's Avatar
Very good. Thanks everybody!
