Porterbuilt install help
I am currently mocking up my engine and transmission. It's a SBC with a 700R4. I am running into 2 problems, first my oil pan hits the rack and second how high should the transmission crossmember be in the frame. With my transmission at 5 degrees the mount is almost at the top of the frame. I almost forgot it's a 84 with the extreme front.
Thanks |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Porterbuilt install help
The trans is pointing DOWN 5 degrees and the frame rails are level with the ground front to back and side to side?
Yes with the frame laying on the ground I can't get the trans to 5 deg without the engine hitting the rack.
Posted via Mobile Device |
Seems like if you lowered the back of the trans the front of the oil pan would pivot up.
Can you post pics?
I'm actually raising it to get to 5 deg
#6 | |
Your trans tailshaft should be at -5 degrees (5 degrees down) and the rearend should be at +5 degrees (5 degrees up). I can't imagine the trans crossmember needs to be at the top of the frame rails.
#7 | |
Steeds sells offset bushing to drop you rack down 1/4". You will have to have them machined down to be the same diameter as the bushing holes on the rack. But, it worked for me.
///Relaxed Atmosphere |
So you had the same problem ?
Posted via Mobile Device Posted via Mobile Device |
#11 | |
I'm still working on the drive line issues with Nate
#12 | |
#13 | |
You might contact one of the aftermarket oil pan manufacturers and see if they can help.
I'm using the rack supplied by Nate
#15 |
You can email me the pics and I can post them for you if you want danwade66@gmail.com.
Also, your trans tail shaft is pointing down to the ground 5*? You running the level 3? Send me the pics and include some of your motor mounts, oil pan and trans and I will post them up for you. |
#16 | |
#17 |
#18 |
Here is the photo's MURPH sent. The trans crossmember seems fine in this photo but I assume it needs to go up a bit further? Can't really rell whats happening with your R&P and oil pan though.
#19 | |
#20 |
The rest of your pics
#21 |
I feel that either pan or rack is the problem. I went up to the shop today and I can get the carb mounting surface to 3.5deg and I have just a lil daylight between the rack and oil pan. I wonder if the uninterrupted rack is a little thinner than the rack I have. The motor is a 383 so I don't know if there is a smaller oil pan I can use and it still clear the rack.
#22 |
Should be the unisteer R&P then, that's what I got.
Give Nate a call, he is really good about responding and helping. He would even send you some custom mounts if necessary. I dealt with him a lot and he was great at helping or resolving any issues I had. |
#23 |
I am considering just leaving the pinion at 7 deg and running a double cardan joint drive shaft or putting a washer on the rack to move it forward just a hair.
#24 |
Could try something like was mentioned above like these http://www.summitracing.com/parts/sd...4011/overview/
I would still check with Nate, moving things messes with geometry. |
#25 |
I spoke with Nate about the above process. He believed that the amount that the rack was going to be moved would not create any noticible geometry issues.
