06-20-2015, 07:26 PM | #1 |
Rare '67 ?
Hi, I'm a new Chevy owner and could use some guidance. We have a '67 C10 4WD short bed, 6 cyl, 3 on the tree. The guy helping me with body work says it's a rare truck because it has leaf springs in the rear instead of the coil springs. Apparently he hasn't seen this combination of truck before. He says its worth a lot of money (not my reason for owning it by the way) if it's done right. I've been told the gearing was special ordered with a final ratio close to or over 5.0! I also thought the 4WD made it a K10, but the id plate in the glovebox calls it a C10. Needless to say as a new Chevy owner and new to restoration I could use some suggestions on how to proceed. So far the exterior is shaping up nicely, interior as well. I would not call it restoration grade, but it looks great. Almost ready for paint. Engine compartment, drivetrain, undercarriage, have had no work done (except POR on frame). Some questions I would ask a seasoned Chevy guy would be: Should I spend a lot of money to fully restore this truck, or make it look nice and drive it with pride? Should I Convert to V8 with newer tranny? Should I paint it a cool color or paint it the original pale yellow? Is this combination really that rare, and is it really worth a lot of money? I don't want to think of it as an investment, but don't want to ruin a truck that is or could be special. I'll take any and all feedback. Thanks, Rick
06-20-2015, 07:32 PM | #2 | ||
"I ain't nobody, dork."
Re: Rare '67 ?
Do your truck the way you want. Don't take someone else's suggestions and run with them. I know you're getting ideas, but if you're happy with the I-6 and the TOTT leave it. If you desire a V-8 with an auto... then go for it.
I don't think any 4x4's in the 67-72 years had coil spring rear ends... but I could be wrong. If your SPID shows a "C" 10 then someone converted it to a "K" 10. Posy a picture of the SPID on the glovebox door. Gary
06-20-2015, 07:43 PM | #3 | |
Re: Rare '67 ?
With over 200,000 made that model year no variant could be called 'rare'. Build what you want. If you do quality work nothing you do will lower the value of your truck. |
06-20-2015, 09:18 PM | #4 |
Roadtrip!
Re: Rare '67 ?
A 67 4x4 shortbed would be somewhat rare. Any shortbed 4x4 would be worth some decent money if "done right". I would guess the gearing to be 3:73 or possibly 4:11 were available. All 4x4 trucks were leaf springs front and rear.
If you could post a pic of the options inside the glovebox door we can break it down for you.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
06-20-2015, 09:41 PM | #5 |
Re: Rare '67 ?
to my best knowledge they were called C10s even until 1970 at least where the K came from is the vin number if there was a K in the begining of the Vin it was a factory 4x4 so then they started calling them K10s Even having C10 fender badges
Nope never seen a coil spring 4x4 but 2wd came both ways so thats probably where this guys confusion is stemmed |
06-21-2015, 06:51 PM | #6 |
Re: Rare '67 ?
Not taking 4x4 into consideration. Chevys usually had the coil rears and GMC had leafs atleast on 2 wheel drive trucks this could be different with 4x4 though
06-21-2015, 08:23 PM | #7 |
I am a Referee of life.
Re: Rare '67 ?
I've never seen a 4X4 with coils in the rear,even converted. Most who convert,want to have off road capability and the leafs are much better for that.I would really be surprised if it were a factory 4X4 if it has a C code on the SPID. Keep in mind that you need to check the SPID against the VIN to make sure the GB door is original.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-22-2015, 02:06 AM | #8 |
Re: Rare '67 ?
I am by no means an expert on this and hopefully some of the other members will help here. But it is not so much a rare but a very nice desirable truck. Being a shortbed 4x4 is what makes it that way. The c10 part of it is either 1 of two options. It was converted to 4x4 or it could be factory. That doesn't help much but they did not call them k10 in till after '70. The inline 6 and 3ott was a common setup. Any rarity it would have will be in the smaller options listed on the spid. But what it comes down to is, how would you like the truck?? Do it that way. These are very popular right now and not much you could do to lower the value. Sounds like you have a really nice truck. Enjoy the heck out of it
06-22-2015, 06:25 AM | #9 |
Re: Rare '67 ?
The guy doing your body work doesn't know what he's talking about. That's why I didn't red any further than his coil spring comment. Was there a bar stool stuck to his butt? Or, is he just a person who professes his ignorance? You're in the right place now if you need accurate info. All 4wds had leaf springs front and rear.
EDIT: Ok, I read more. No 1/2t trucks came with such a low gearing and if it had any optional ratio it would be listed on the SPID. But, since it appears to be a C/10 on a 4wd frame that will not be the correct SPID...unless the glovebox door was retained. I have to wonder if the 4wd frame is a '67 frame or even a 67-72 at all. Do the rear shocks stagger forward and rearward or do they both face forward? I would need to see the front of the frame to know more. Are the radiator core support mounts riveted to the frame? If it's a '73+ frame the core support would have been moved back and mounts relocated or new holes drilled with some sort of bushings rigged up inward over the frame.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 06-22-2015 at 06:35 AM. |
06-23-2015, 10:35 PM | #10 |
Re: Rare '67 ?
Look up the vin an model number because it might be a 2wd converted cause the c's are usually 2wd an there's a lot of them that's been converted a quick easy way is see if the frame vin matches the cab vin if it doesn't it indicates frame swap ... Vins located on driver side engine compartment frame rail ... Hope this could be helpful
06-27-2015, 03:18 PM | #11 |
Re: Rare '67 ?
Wow, thanks for all the great feedback. I will check the VIN numbers and the info in the glovebox to see if there are discrepancies. I am excited to hear everyone say something along the lines of "do what you want with it", that will make it a lot more fun! I will post pictures as soon as I figure out how to. Thanks everyone for the guidance!
06-27-2015, 04:12 PM | #12 |
Re: Rare '67 ?
2wd Vin started with a c, 4wd Vin started with a k. My 67 longed starts with a k. 67 Factory 4wd are rare. Build it how you want.
06-27-2015, 04:18 PM | #13 |
All about them K’s
Re: Rare '67 ?
Theres been a lot if these "rare truck" threads lately. Aside from the very few 100% un touched low mile immaculate factory condition trucks that come up once in a while, these trucks arnt rare. Thats my .02. Do what you like with it and most importantly drive the heck out of it and enjoy it. I prefer factory style restorations but to each his own and i can appreciate ALMOST all tastes.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
06-30-2015, 10:01 AM | #14 |
Re: Rare '67 ?
Ok, we found the glove box, picture attached. So it is in fact a K model. Now a technical question: The transmission slips out of third gear, and the trans guy says the "fork" that moves from one gear to the other is worn out. See picture below. Does anyone know where we can find one of these? Can we make one, and if so what material would we use?
06-30-2015, 11:49 AM | #15 | |
Re: Rare '67 ?
06-30-2015, 10:31 AM | #16 |
Re: Rare '67 ?
I hope your tranny guy is smarter than your body guy?
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
06-30-2015, 10:49 AM | #17 |
Re: Rare '67 ?
I'm going to go against the grain, and no offense to those above, but apparently they haven't paid attention to model specific production numbers.
According to your spid your truck is a KS10734, which is a FACTORY 4x4 SHORT BED FLEET SIDE. These trucks are ABSOLUTELY RARE. There was ONLY 1,046 shortbed fleet sides built and 1,229 short bed step sides built. http://67-72chevytrucks.com/vboard/s...d.php?t=104816 Now, does this make your truck valuable... kinda. I'd research what 1967 4x4's shortbeds are selling for (most will likely be conversions or cut down long beds) and add a few grand for being a factory truck. So, no, you're not sitting on any kind of gold mine, but it is more valuable than your typical 4x4 (again, most are either longbeds, or cut down short beds, or converted short beds). Personally, I'd like to see this one done back original.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 06-30-2015 at 11:00 AM. |
06-30-2015, 10:55 AM | #18 |
Re: Rare '67 ?
Being an actually '67 K10 SWB changes everything. You have a low production factory vehicle. By overall industry standards your truck is rare.
06-30-2015, 11:35 AM | #19 |
Re: Rare '67 ?
Looks like the consensus is to do a stock restore ,,, I agree ,, that spid changes everything ,, I was guessing you had a cut and paste truck , like so many are , but yours is original , and a great model to have original
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
06-30-2015, 12:08 PM | #20 | ||
Re: Rare '67 ?
Numbers don't lie. So when you have proof like that it makes it all the better. Lots of cats come and go with what the say are "rare" trucks that usually end up being a cobbled up hot mess.
Nice find... absolutely there are not many of those trucks around. Gary
06-30-2015, 03:59 PM | #21 |
Re: Rare '67 ?
nice find. any pics of the body?
Posted via Mobile Device |
06-30-2015, 05:52 PM | #22 |
Wide n'Low
Re: Rare '67 ?
Glad someone else chimed in with production numbers, and that you found the SPID. I happen to have on myself, and might be able to shed some light if you have some questions. When I got mine, it had several items not correct, such as a step side bed, 68 fenders etc... but she's going back to her roots.. more or less. Unfortunately, my cab is pretty bad off, so i may just swap it with another one. (keeping the VIN tag of course)
Best of luck and hope you build it and make it your own!
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
06-30-2015, 06:12 PM | #23 |
Moderator
Re: Rare '67 ?
I'd still build it the way I wanted, regardless of a sticker.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-30-2015, 06:41 PM | #24 | ||
Re: Rare '67 ?
This... 100%.
Gary
06-30-2015, 10:47 PM | #25 |
Born Psycho
Re: Rare '67 ?
i'll catch some flack for this but i totally agree. save everything that is original to the truck in case you ever decide to go "stock" again. unless you cut/weld on it it can be put back to original. IF it was a CST loaded with factory options i would say build it stock but it is a bare bones truck so build it how you want.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
