Old 06-20-2015, 07:52 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
MC years/interchangeablility
Will a MC from a 1985 work on an 1983? I have a MC w/ hard lines to the proportioning valve from a 1985 I want to put on my 1983. I included some pics. I think my 1983 MC has an internal seal problem because after I bleed the brakes and get the pedal where it is nice and firm, a couple pushes later it gets soft again and goes to the floor. Thanks,
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-20-2015, 10:37 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: MC years/interchangeablility
Answered my own question, will not work. Different GVW ratings.
Old 06-21-2015, 10:39 AM   #3
Keith Seymore
Keith Seymore's Avatar
I'd try it and see.
Here's all the ways (that I can think of, offhand) that a master cylinder swap will not work:
bore size
quick take up vs non (affects the diameter of the housing at the rear)
flare size
ISO vs SAE flares
outlets on inboard side vs outlet on the outboard side
front outlet goes to front system vs front outlet goes to rear
Judging by the pics you posted it looks like it would drop in. I'd try it, checking for pedal travel, effort and force. Especially since it is a relatively easy swap.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-21-2015, 11:56 PM   #4
69heavychevy
69heavychevy's Avatar
It should work...I swapped the master cylinder in my 80 C10 with 1.25" rotors and 2" rear brakes with a MC from an 83 C10 with 1" rotors and 2-3/4" rear brakes. I swapped over the booster and MC hard lines as well since my original hard lines wouldn't line up correctly to the 83 MC.
BTW my original MC looked like the one in your second pic and my replacement looked like the one in the first pic.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
