06-21-2015, 01:11 AM | #1 |
86 k20 wheels
So I finally got new wheels well new to me at least. They were my buddy's there the typical 8 hole wheel. The thing is he didn't care for his truck like I do and there aluminum non clear coat wheels with quite a bit of oxidation what's the best way to get them looking back to a mirror finish?
1986 chevy k20 4inch lift 35 inch duratracs |
06-21-2015, 10:53 AM | #2 |
Re: 86 k20 wheels
Mothers has a mag and alum polish and use their powerball it goes in a drill making it easier.
06-21-2015, 11:25 AM | #3 |
Re: 86 k20 wheels
Hi there andrew,
Thanks for your response I acctually tried that and didn't get what I was looking for that's why I came here
06-21-2015, 10:33 PM | #4 |
Re: 86 k20 wheels
Take a picture of the wheels so we can see what your working with.
06-22-2015, 12:18 AM | #5 |
Re: 86 k20 wheels
I have a set of welds when I got them they where in bad shape from setting in the guys yard where he parked the truck I had to wet sand mine 800-1200-2500 and use some red bar buffing compound then mothers with a power ball
06-23-2015, 01:13 PM | #6 |
Re: 86 k20 wheels
Here's the shape they are in now
06-25-2015, 03:10 AM | #7 |
Re: 86 k20 wheels
If you want them to shine like chrome its going to take wet sanding and buffing.
06-25-2015, 11:49 AM | #8 |
Re: 86 k20 wheels
I have been messing around with different ways to try and speed up the proses of polishing aluminum wheels and other items. I have started off using scotch brite pads first(dark red). Then jump to wet sanding. You can be a bit more aggressive with the scotch brites use at once, over working your way up with wet/dry sand paper.
Side note Its very easy to convert a standard bench grinder into a buffing wheel. Tear it down remove the shaft and have somebody or do it yourself. Make a longer shaft so you can buff wheels. I did mine for under 20 bucks.
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
