Old 06-21-2015, 08:31 PM   #1
jadedbird
jadedbird's Avatar
Removing a th359 HELP!?
How hard is it to remove a th350 from a 350 sbc?
What tools do I need and is there like a write up? They're both out of the truck but the guy I'm wanting to buy from doesn't want to remove them and I don't want or need the th350 and I'm wanting to run a 4 speed.
YouTube is no help from my searching.
jadedbird is offline   Reply With Quote
Old 06-21-2015, 08:41 PM   #2
WOLFMANmike
WOLFMANmike's Avatar
Re: Removing a th359 HELP!?
hey bud this is so easy you will only need to bring a set of standard wrenches with you i cant for the life of me remember the size but if you bring a full set you will have the right one .. i want say its a 9 sixteenths or a 5 eighths but dont quote me ... then its just simple as taking out the bolts have a good size pry bar or a flat head driver to seperate but most times that not even a issue ... hope this helps ya man .... happy truckin
WOLFMANmike is offline   Reply With Quote
Old 06-21-2015, 08:58 PM   #3
jayoldschool
Moderator
It's an automatic. No input shaft. The torque converter is bolted to the flexplate. You'll need to rotate the engine to get the converter bolts.
Bring a socket set. You'll have it done in 5 minutes.
jayoldschool is offline   Reply With Quote
Old 06-21-2015, 09:43 PM   #4
WOLFMANmike
Yeah it will all go very easy
Old 06-21-2015, 08:50 PM   #5
jadedbird
jadedbird's Avatar
Alright that's what I figured. I assume the input shaft will freely come out of the motor pretty easy?
Old 06-21-2015, 08:56 PM   #6
rcnutt
rcnutt's Avatar
9/16 and 5/8 or 11/16 for the converter to flex plate bolts. You're going to want to keep the converter with the trans. It'll save a big mess. Just make sure it stays all the way in the trans when you separate them
rcnutt is offline   Reply With Quote
