Old 06-24-2015, 10:36 PM   #1
jasonmiddlebrooks
jasonmiddlebrooks's Avatar
1970 rear control arm question
So I dropped the rear end out of my 70 c10 to clean it up, replace bushings, shocks, coil springs, paint, etc. I noticed one of the rear control arms have a piece wielded on the top and bottom. Is this something that they would do at the factory? My Dad bought this truck new in 70 and has been the only owner. He wrecked it right after he bought it new but does not remember anything done to the rear end (but that is not to say something was done). Here are some pictures. Thanks.
jasonmiddlebrooks is offline   Reply With Quote
Old 06-25-2015, 12:12 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 1970 rear control arm question
I have only seen this on 3/4 ton arms. I think normally they are riveted one, not welded. I have a set at home and would have to look again. Since the 3/4 ton truck would haul more weight, GM did this to reduce flexing and breaking of the arms.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-25-2015, 02:36 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
x2 on that, the only bracing I've ever seen was the riveted plate on the C20's.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
