Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 06-29-2015, 11:51 PM   #1
gearheads78
gearheads78's Avatar
Robinair A/C machine won't work
Anyone know about these machines? Just bought a used (barley) Robinair 17800B recovery / recycle machine for my home shop. It was bought from a closed down shop at auction so I am stuck with it so I need to get it working.
All of the fuctions start but does not matter if I am trying to recover, recycle, fill the unit from a fresh tank of 134 I get a HI-P (High Pressure) message and the function stops. Ive checked all the trouble shooting in the manual and talked to tech support at Robinair (They were no help other than offering a number to a repair man)
Ive hoping this is a common issue someone can give some pointers on. It looks near brand new and the run meter only shows 5 lbs of refrigerent has gone though the filter.
thanks in advance
gearheads78 is offline   Reply With Quote
Old 07-02-2015, 05:12 PM   #2
68c10airstream
68c10airstream's Avatar
Re: Robinair A/C machine won't work
Last time i used one was in 1999, so it's been a while! I believe you have a recovery tank on board and what happens to our shop unit was exactly the same situation. We would remove the tank, turn it upside down, look at a temp/pressure chart and we had to bleed the non-condensable gasses off (air) to get the pressure down to spec. The entrained air raises the tank pressure and it has no place for it to go, as this comes from the cars being evacuated and recharged, and hoses being connected/disconnected as this introduces air also. From memory i think at 70 degrees it was to be 80 psi max.
The procedure my boss showed me was to remove the tank at the end of the day and turn it upside down The reason for being upside down was there is dip tubes for the valves and if it was upright you would bleed off refrigerant, not air, so when inverted the air goes to the top (actually the bottom of the tank) and the dip tubes can then draw off the air. As you bleed the pressure/air from the tank inadvertantly you pull a little regrigerant along with it and it cools the tank which lowers the temp/pressure. We used a temp gun to shoot the tank surface and look at the chart at the same time. Hopefully this is close and you could now do a google search to verify. Just thought i would post as i had a few minutes to spare, Good luck, Brian F.
68c10airstream is offline   Reply With Quote
Old 07-31-2015, 08:19 PM   #3
truckdude239
truckdude239's Avatar
Sounds like there is 2 much freon int he machine i once over filled mine when i was putting freon into the inside tank and with wouldnt let me do anything untill the level was down.
Other note mine broke and had to have a soilnoids r3placed this week
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-31-2015, 10:24 PM   #4
gearheads78
Ive tried everything. I'm going to have to have a tech look at it.
Old 09-01-2015, 11:14 PM   #5
chebyshortbox65
chebyshortbox65's Avatar
Sounds like the storage tank might be full last one we called a tech for that same issue he said to plug it in an leave ot it will purge it self also said don't use an extension cord less them 12 gauge they have issues with low voltage just my .02
chebyshortbox65 is offline   Reply With Quote
