Can anyone identify this, thx
I don't know what this linkage is for and if I don't need it, it can go in the for sale pile , anyone know.
Re: Can anyone identify this, thx
Looks like to me a shifter rod linkage assy for an automatic transmission. The year I really dont know..
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
Never Ending Projects
Yep, looks similar to what I took off my '68. Definitely auto shifter linkage. No idea on the exact year.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() ![]() Join Date: Apr 2012
Its 1966 TH 400 shift linkage. edit. Jon
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK Last edited by 60-66; 07-02-2015 at 01:55 PM. |
![]() Join Date: May 2010
Yep the same one I'm about to pull off my 66' that had a TH 400.
It only has original paint once |
It looks like my 66 TH400 linkage too. I know this isn't a parts ad but I really could use one piece of it for mine so please let me know what you want for it and I'll take the whole thing now in case I miss it going to the sale pile. PM sent. Thanks, Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" Last edited by HOTFUN; 07-02-2015 at 07:16 PM. |
#7 | |
Posted via Mobile Device |
Holy cow. I am on road but will get with you later today. That's crazy. Thanks mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
#9 | |
Awesome job!
All you need to do is grind down the knuckle or drill your hole to match, this was a 3 in the tree linkage so it was a lil bigger.
Linkage for a 1966 Hydromatic three speed transmission.
This is what my extended power glide linkage looks like on it. Wasn't happy it works but I had to tweak bell crank a little to keep it from binding. I bet I can finish that one off and nobody would know it. That is just awesome. I'll send you a pm. Thanks, mark
That looks awesome, great job
Notice the Turbo 400 electric kickdown wire and my factory tach wire coming out of the grommet at top and down firewall with a clip and both are in the same place from the 66 parts TH400 truck. I also used a NOS 74-77? GM factory tach filter that GM used on the first HEI's was put to them older tachs. I mounted it right off the orignal coil bolt and the tach harness(with a new GM HEI tach lead added) plugs into the filter and the other end of the filter has another lead to plug into the HEI cap. All GM just a little more improvement in driveability and it will be hid behind the air cleaner.
